Pullback riser for '07 Dyna
Old Dec 2, 2006 | 12:16 AM
Jetstream's Avatar
Jetstream
Default Pullback riser for '07 Dyna
I'm looking for a 2"-3" pullback riser for my '07 Dyna Super Glide Custom. Does anyone have a link to one? What is the maximum length pullback riser I can use without having to change the cables? Thanks!
Old Dec 2, 2006 | 12:48 AM
blkdimon8's Avatar
blkdimon8
Default RE: Pullback riser for '07 Dyna
I just replaced my 06 FXD stock ones with 4" pulled back risers, only thing I had to do was straightend out the brake line a bit. Hope that helps, the speedo will stand up straighter though.
Old Dec 2, 2006 | 10:34 AM
Mascman's Avatar
Mascman
KC International has a ton of stuff ant really good prices.
I bought a set of Duece Style risers and some drag bars for my brother.
The Duece risers may be a little more than you want, but there are other styles to choose from.
Here's the setup I got for my brother:
Old Dec 2, 2006 | 10:44 AM
PowerCobra98's Avatar
PowerCobra98
ORIGINAL: Jetstream
You wouldn't need to change your cables if you just did a 2" pullback but if you'd like to change your cables to the diamondback style plus get rid of that ugly hard brake line I have all front 4 cables you need that I'm selling for dirt cheap. I swapped my bars so I had to get longer cables. You can read about them here if interested: https://www.hdforums.com/m_983099/mp.../tm.htm#983099
Old Dec 3, 2006 | 12:40 AM
ak602's Avatar
ak602
Mascman how is that speedo mounted to those risers. That setup looks sweet...........
Thanks
Aron
Old Dec 3, 2006 | 06:46 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: blkdimon8
I did the same...................
DougJ
Old Dec 4, 2006 | 01:00 PM
Jetstream's Avatar
Jetstream
Thanks... I have a Custom and my mechanic says the 4" risers cause the handlebars to run into the tank mounted speedo.
Old Dec 4, 2006 | 01:05 PM
jmbear328's Avatar
jmbear328
Not sure if your looking but I have a pair of fat chrome pullback risers and a set of drag bars that I would be willing to sell pretty cheap, since I just installed the setup thats on the new 07 CVO Dynas.
John
2013 heritage classic
May 6, 2014 06:10 AM
CJinNH
Jul 6, 2011 11:28 PM
robbieaz62
Jul 1, 2009 05:16 PM
WERE TO
May 26, 2008 10:19 PM
hddave2
Oct 6, 2007 06:35 AM
