New Apes And Cables Do I Need An Idle Cable
Old Dec 25, 2011 | 08:16 AM
Fat-Bob-Brad's Avatar
Fat-Bob-Brad
Default New Apes And Cables Do I Need An Idle Cable
As it says guys i am in the middle of putting my new apes on the question is do i need to install a new Idle cable i an sure i have read some place on this site that it will be ok without ??
Oh I have a 09 FXDF (Fat Bob)
Thanks Brad
Old Dec 25, 2011 | 08:57 AM
Shovelhed's Avatar
Shovelhed
I never ran one with my shovel(carb).
Old Dec 25, 2011 | 09:02 AM
k&j eglide's Avatar
k&j eglide
Why wouldn't you?
Old Dec 25, 2011 | 09:53 AM
zukeeper's Avatar
zukeeper
I don't run them ,havent for decades with zero problems. no need for them and they just clutter the bars . They wouldn't be there if it wasn't a sue for any reason country.
depending on your carb , you may have to space up the bracket that holds the cable to the top of the carb to get the slop out of the throttle cable. At least on SS carbs the idle cable pulls in the opposite direction enough at closed throttle to keep tension on the throttle cable, a couple washers under the bracket and the throttle cable is perfect though without the idle cable
Old Dec 25, 2011 | 10:46 AM
BoozerHi's Avatar
BoozerHi
Ya don't need it, but it beats the hell out a stuck throttle in traffic. Can also be used as a backup throttle cable to get ya home.
Old Dec 25, 2011 | 11:28 AM
wideglidebob's Avatar
wideglidebob
seems like a no brainer why woulden`t you
Old Dec 26, 2011 | 07:45 AM
Fat-Bob-Brad
Beacuse it looks SOOOOOOO much cleaner without when you have apes on the lees crap hanging from the bars the better IMO.
Will the EFI engine / throttle return ok without it though a accecpt the carbed engine will good point about using it as a spare throttle cable though if you have a problem.
Thanks Guys Brad
Old Dec 26, 2011 | 11:25 AM
zukeeper's Avatar
zukeeper
never seen a throttle cable get "stuck" . If one ever did , I would think that by having a clutch / brakes / kill switch / ignition switch...that a person wouldn't be in any trouble.
if a person is that worried about a spare , a new cable would roll up tight and be easy to carry
Old Dec 29, 2011 | 08:40 AM
Bigfoot1's Avatar
Bigfoot1
I've always taken mine off too, but yesterday on the way to work the cable broke.20 degrees at 5:30 in the morning, 15 miles from the closest town Once I got it home, on a trailer no less, I found out the throttle sleeve was rolling past the housing and bending the cable back and forth enough that it only lasted about a month. I put 2 new cables on it and will probably just leave it be for now. Was looking at a few of Indian Larry's old bikes and thinking of trying to go more that route. His throttle cable is just run in the bars. Gonna check into that.
morleyz
Mar 11, 2018 08:03 PM
800screws
EVO
Nov 29, 2015 10:58 AM
95yj
Exhaust System Topics
Dec 28, 2012 11:19 AM
coz300
Jan 18, 2012 05:42 PM
obijohn
Sep 13, 2011 02:38 PM
