Torx Sizes
Old Feb 24, 2012 | 11:11 PM
macnab_sf's Avatar
macnab_sf
Mind the diff between torx and torx plus. Get the ones you need.
Old Feb 25, 2012 | 04:05 AM
JerryDinMD's Avatar
JerryDinMD
where did you find that right angle Torx? ive even looked online and cant find one ! That's what I need is a right angle one.
Old Feb 25, 2012 | 04:12 AM
JerryDinMD's Avatar
JerryDinMD
they arent rusted on -just tight as **** and hard to get to-at least the right side is-i tried an allen on it-one is a little too big and another is a little too small and didnt want to press my luck and strip it out
Old Feb 25, 2012 | 04:41 AM
Krazy8s's Avatar
Krazy8s
A Torx or a Torx P (plus) can mean the difference between stripping a head or not. Been there, done that, got the T shirt......
Old Feb 25, 2012 | 06:21 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Jerry try a little heat on the bolt with a heat gun before you wrench on those torx screws. I have found through experience the hard way that this for me is the way to go. Heat it a little and push straight and firm and turn slowly, that has worked for me.
Old Feb 28, 2012 | 07:52 AM
davedyna's Avatar
davedyna
Jerry,
Same issues with same project myself. Socket head T-47 fits on the bolt but could not get a 3/8 wrench on it due to the frame. Found that I could use a 1/4-3/8 adapter (very short) and just get a 1/4 socket wrench on it. I definitely second PB blaster (maybe a little heat first). Total pain in the *** for what shoud be a 5 minute project on that side.
Also try this link
http://www.zdmak.com/wbstore/main.as...CTMP=1&LowCt=0
Good Luck
Dave
Old Feb 28, 2012 | 01:39 PM
JerryDinMD's Avatar
JerryDinMD
yea i ended up getting a #47 socket today and working on getting them off-and to make things more of a pain-one of them on the left side striped on me-so now i have to wrk even more to get that bastard out !
Old Feb 28, 2012 | 03:14 PM
ynots's Avatar
ynots
I picked up the right angle torx at a local tool supply. I went out in the parking lot and made sure it was the right size, then broke it loose while I was there. I then went back inside and just bought the torx bit and used a wrench to tighten it. The bolts are tight, there was a post awhile back were a guy used a soldering gun to heat the bolts before he broke them loose. the loctite can be a bitch in tight spots
Romeo
Sep 10, 2025 04:25 PM
YeOldeStonecat
Aug 6, 2020 03:54 PM
jurakat1111@gmail.com
Jul 7, 2016 10:53 PM
Airborne350G
May 18, 2009 03:55 PM
flyboyron
May 5, 2009 03:34 PM
