Race Tech Emulators: Clicking sound?
Old Feb 27, 2012 | 07:28 PM
AQuartLow's Avatar
AQuartLow
Default Race Tech Emulators: Clicking sound?
I installed a set of chrome fork lowers, Race Tech springs and their Gold Valve Emulators last night on my 2005 FXDL. I lowered it one inch using the supplied top out springs and cut the supplied aluminium pipe to an appropriate length for preload. I made sure to use the supplied washers above and below the spacers.
This morning at the shop I noticed a clicking sound when I compressed the suspension. Anyone know if this is normal with the Emulators? Think I messed something up? It wouldn't be the first time!
I wish there wasn't snow on the ground as I want to test these things out. I'm a little concerned that the suspension isn't as stiff as I suspected (eventhough I went to the Screamin' Eagle Fork oil) but I won't know for sure for another month or so.
Any thoughts?
Old Feb 28, 2012 | 08:21 AM
AQuartLow's Avatar
AQuartLow
Bueller?.....Bueller?.... Bueller?...... Anyone?
Old Feb 28, 2012 | 08:30 AM
PHA-Q's Avatar
PHA-Q
Pull the caps and springs out and put a turn back into the emulators... I had to mess with mine three times before i found a Happy place..
Old Feb 28, 2012 | 12:05 PM
07bobber's Avatar
07bobber
PHA-Q: how many turns did you give your emulators? what do you weigh, im trying to get an idea of how to adjust mine for install...
Old Feb 28, 2012 | 07:53 PM
AQuartLow's Avatar
AQuartLow
I set mine up with 2 turns in from having no tension on the spring. That's what was prescribed in the instructions though they said that that is a baseline and individuals may want to tune differently.
Here's another question related to this whole thing: it was suggested by a buddy that I increase the preload by putting in longer spacer tubing. The thing I don't get is how that would increase preload if the springs are a straight rate spring. I understand how this works on progressive rate springs but not straight rate. Am I missing something?
Old Feb 29, 2012 | 12:59 AM
SURFOR Chop's Avatar
SURFOR Chop
I never had any clicking sound from mine ... WRT your friends suggestion ... I think all you would be doing would be adding back some of the lowering height ...
... actually, come to think of it some more ... and having consulted the installation instructions here http://www.racetech.com/articles/emulatorfitting.htm ... I believe your rebound springs were twice as long as the stock springs you removed ... hence, while adding a longer spacer at the top of the main springs would compress the spring a little ... it might offset the rebound spring a little, but it shouldn't affect your lowering by very much if at all ....
... I believe it would affect your preload somewhat ... even if yours is a 'straight rate' vice progressive wound spring ...
Old Mar 1, 2012 | 12:07 PM
PHA-Q's Avatar
PHA-Q
I started at three turns in. Im at two now. I trimmed my spacers three times to set up sag where i wanted it. I weigh 200-2010lbs
Old Mar 1, 2012 | 01:30 PM
07bobber's Avatar
07bobber
Pha-q: thanx im around 235-240 so ill start at 2-1/2 turns to start
Old Mar 1, 2012 | 11:29 PM
AQuartLow's Avatar
AQuartLow
You wouldn't happen to remember what you ended up with for spacer length, do you? I cut mine to 11.3 cm. I'm 180lbs. Thanks!
LA_Dog
Dec 20, 2015 07:27 PM
smartass12
Jun 4, 2014 11:42 PM
Tortoise98
Mar 28, 2012 03:30 PM
a2wheelerte
11
Jan 18, 2008 03:52 AM
Beagle1
Apr 23, 2007 12:13 AM
