installing a tach
Old Mar 1, 2012 | 08:47 PM
strongwood's Avatar
strongwood
Red face installing a tach
Does anyone know if a 99 Wide Glide had a factory tach as an option?
I have bought a tach and bracket and am ready to wire it up. My service manual has a wiring diagram but before I splice into any coil wires, I wanted to know if the open plug under my tank might be for a tach.
I do not see any reference to this plug on the wiring diagram
Anyone have any suggestions on the best place to wire it up if the connector under the tank is not a tach hook up?
Thanks
Old Mar 2, 2012 | 07:27 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Dan,
As far as I'm informed there's no plug to hook up the tacho.
How many wires and what color did you find at this connector?
As for the tacho: what kind of tacho do you want to install?
If it's a tacho similar to the one that's mounted to the FXDL/X/P in here's a way to hook it up:
Old Mar 2, 2012 | 06:18 PM
strongwood's Avatar
strongwood
It is a Drag Specialties tach.
The wires are a different color than your diagram but I do know where they go.
Green negative coil
Red and blue to one side of ignition switch
Both black wires to ground
Also, I do have a pink wire going into the speedo connector. It appears to be cut then spliced back together
Here are a couple of pictures if the connector I am looking at
there are 3 wires going to it but I have not peeled back the sleeve to see what color they are
07_Dyna
Aug 22, 2014 06:41 AM
bolillo57
Jun 17, 2013 04:05 AM
bolillo57
Jun 8, 2011 07:37 PM
jbied
Oct 25, 2010 12:30 AM
RoosterDick
Dec 8, 2006 02:19 AM
