Proof you don't need a tuner
Old Apr 16, 2012 | 07:32 AM
  #131
Hobiesun's Avatar
Hobiesun
Hello all. I would have totally expected the FI to compensate for pipes and maybe an AC. Although, I just bought a "48" at my dealership that was traded in with 500 miles on it. All they did was Vance and Hines slip on mufflers and heat shields. The bike runs like hell. Surges, misses while on a constant RPM (Cruise). WOT bike hauls great, but any kind of slower consistant speed and she sputters and just does not run right. I took the intake and throttle body off. Cleaned the injectors, made sure nothing settled in the tank(you never know). I polished out the intake and throttle body. That is where I am at now. I haven't tried it now and yes I realize i made the lean issue worse until I tune it. I wont run it until I get a tune in it. I tried a few different things before to get it to run smoother/richer. 93 oct. Mixed a little 110oct with it. Put a step colder plugs in it. Ran some sea foam through the tank. Still was running lousy before I took the intake off. I have a new AC and different Pipes on order along with which ever tuner I decide to get. So I don't know. Slip on pipes have seemed to be too much for the 1200's EFI system to compensate. Any thoughts? I am sure the bigger bikes have a better designed motor.
Old Aug 9, 2012 | 01:27 PM
  #132
WIDERGLIDER's Avatar
WIDERGLIDER
I'm still running the Sage I air cleaner, and slip ons for a few thousand miles, and the bike is running great WITHOUT a tuner...just sayin..
Old Aug 9, 2012 | 02:06 PM
  #133
Tnbrit's Avatar
Tnbrit
Default Different Expierience
I really wish I had the same results as the original Poster,& a lot of others in the thread,I changed the Pipes on my 11'FXDF for a 2-1 system,& the bike runs really poor,lots of back fireing bad decel popping,feels relatively gutless,don't know why but my ecu has definately not adjusted to the new system,not making a point,just a very different result.
Old Aug 9, 2012 | 04:43 PM
  #134
jojo2dog's Avatar
jojo2dog
every time i have the bike serviced it comes back running like ****,disconect the battery for at least one hour,let it sit,for some reason this seems to start the ball rolling,reconect take the bike to a open road run it up to about 5000 rpm in different gears then backing off and letting it back to about1500 rpm like you are brakeing in a new motor after that it will get better with time till they service it again. why this works I have no idea, but it sure helps mine.had it serviced and headed for my sons ran like **** unhooked the battery at his house for sum reason don"t remember why when I left his house and headed home was pissed ran the hell out of it started to straiten out. he live on a two lane in the country so I ran it up and down like stated to the city limits by the time I got home it was running decent.and two days later no popping and running good
Old Aug 9, 2012 | 05:08 PM
  #135
grbrown's Avatar
grbrown
Cool
As usual when this subject is raised we get a lot of repeated folklore and misinformation. A stock bike has air/fuel ratios set to maintain EPA regulations. It will allow us to ride over the highest mountain pass, through the hottest desert and coldest winter and maintain those settings.
That built-in adaptability is what you are using up when changing things like mufflers and air filters. It is not there to allow us to change stuff. The days of backyard tuning are behind us. We need to get smart when modifying modern bikes and the only certain way of ensuring all is well is on a dyno.
Old Aug 9, 2012 | 06:28 PM
  #136
952dave's Avatar
952dave
You are retarded. You didn't do anything more than just type out some hypothetical bull crap. I personally have added pipes and a air cleaner to my bike, more than 15,000 miles ago. Unlike most of the mature gentlemen on this forum, I raise complete hell on my bike, even have the stripped 3rd gear to prove it. I haven't had the first sign of evidence that anything is wrong with my bike because of the lack of a tuner. People like you should just hide behind your computer and be quiet. All people like you do is make other riders ignorant and cost them to spend money that could be put in more helpful spots.
Old Aug 9, 2012 | 07:37 PM
  #137
DoomGloom's Avatar
DoomGloom
Thumbs down
Originally Posted by armybrat02
I had a PCIII on my bike and it never connected right with the computer. After about a year it got wet and corroded, messed up my main wire harness. Cost me more that if I had just got the SERT and dyno in the first place.
What does this even mean??? Did you install it yourself?? If it didnt connect right...thats on you...and please clue me in to how it "messed up your main wiring harness." Sound like you shouldnt be working on your bike...or shouldnt be taking it to be worked on where ever you did......
Old Aug 9, 2012 | 07:45 PM
  #138
TORQUEY's Avatar
TORQUEY
I've said it before...I wish I kept the copies of HDs own tests putting A/Cs on and pipes with no tuner. No problems whatsoever.
Stage 2 A/C, full 2:1 pipe change, no cats, adjustable baffle 80% wide open. Runs GREAT. Plugs are consistently a light tan. No carbon build-up inside exhaust. No download. No tuner. No surging. Less heat (no cats). Some decel pop, which, if it were 100% missing, I'd tune it back in!
Old Aug 9, 2012 | 07:51 PM
  #139
rooti's Avatar
rooti
Some of you guys will never know what you are missing until you have a bike that is dialed in properly with a tuner. I always thought my bike ran good too....I was wrong
Old Aug 9, 2012 | 09:56 PM
  #140
FXD_TG's Avatar
FXD_TG
I ran my 2011 FXDWG with full V&H, heavy baffles & Stage 1 for about 1000 miles without doing a tuner / Dyno run, but could tell the bike was running really lean. I tried to go on the cheap with the XiED and while I initially thought it helped, that was short-lived. (Anyone want the thing for 1/2 price?). I took it off and let the ECU go through a couple tanks of gas to get sorted out again and just accepted the fact that until I put it on a Dyno and had it checked I wouldn't know what the motor was really doing.
Turns out it was running WAY lean...
On the baseline run (Red Line), AFR held at a very lean ~15.0 in the 2,400 – 3,500 RPM range that decayed to ~13.5 at 5,500 RPM and then ~13.0 at 6,200 RPM. After the tune & a few hours with the tech getting it dialed-in, it was a solid ~13.5 all the way across the board, +/-.1 (Blue Line)
Bear in mind, Harley's OEM spec is around 14.6, which is pretty darn lean & hot to begin with.
Horsepower & torque also improved, but it was the AFR that I wanted to get sorted out.
Red line = Baseline, Blue line = after the tune.
Your results may vary... I REALLY wanted the stock ECU to bridge the gap, I really did. And, for some perhaps it does.
