Proof you don't need a tuner
Old Feb 10, 2015 | 09:41 AM
  #181
chopperjoes's Avatar
chopperjoes
Default Do I need a tuner
I have a new K & N filter assembly from Roland's and exhaust is True Dual Crossover w/ 2ź" Heatshields & 2 1/4" x 28 1/2" Slip-ons w/Removable Longtail Tips. I'm going to just running the bike like that. It should adjust itself right?
Old Feb 10, 2015 | 09:55 AM
  #182
Simplespeed's Avatar
Simplespeed
$400 air cleaner > tune. Makes sense.
Old Feb 10, 2015 | 09:57 AM
  #183
Simplespeed
Only if you delete the turn signals or go LED cause they get hot.
Old Feb 10, 2015 | 11:05 AM
  #184
Warp Factor's Avatar
Warp Factor
Originally Posted by Red Dragons
All sorts of people in here trying to justify not spending the money on a tune.
And doing quite a reasonable job!
Old Feb 10, 2015 | 11:23 AM
  #185
grbrown's Avatar
grbrown
Red face
Having owned Harleys for over 40 years the over-riding impression over that time has been the multitude of modified Harleys that run rough, or downright rough. It's no different now than when we only had carbs - very few owners are competent at setting them up well.
Old Feb 10, 2015 | 12:11 PM
  #186
Red Dragons's Avatar
Red Dragons
So now you're against all modifications? You really believe that all the emissions related crap our newer bikes come with is the ideal setup for these engines? You're dreaming. And making excuses.
Don't get me wrong, I agree with your point that an idiot with a $600 DIY tuner who doesn't know what they're doing is likely to have a poorly running bike. But if you're saying that stock config is best for power and longevity, vs a proper aftermarket tune, you're just flat out wrong. But, I really don't care what you do with your own bike. The thousands and thousands of us who have tuned and tweaked our bikes are doing just fine.
Old Feb 10, 2015 | 12:40 PM
  #187
grbrown's Avatar
grbrown
Dreaming? You just got that totally wrong! Modern Harley owners are every bit as likely to make a mess of modifying their bikes as in the past, that's all. Nuttin' to do with emissions stuff.
Old Feb 10, 2015 | 12:51 PM
  #188
vdop's Avatar
vdop
I've given up on trying to explain it to people around here. There's a reason this place is the laughing stock of Harley forums. If they enjoy a poor running, underpowered, hot turd that's their problem. Pay now or pay more later. I've seen and fixed enough burnt cylinders/pistons and burnt and stuck valves on bikes with stock maps to see what happens. Not to mention proven it on the dyno over and over.
Only in the eyes of people that are clueless.
Old Feb 10, 2015 | 12:54 PM
  #189
Red Dragons
Ok, clearly you missed my entire point. Never mind.
Old Feb 10, 2015 | 01:02 PM
  #190
IdahoHacker's Avatar
IdahoHacker
Originally Posted by vdop
Ditto.
As we all know, this topic has been beat to death, and for a very good reason:
There has never been a general consensus or agreement on what the phrase "Do I have to" actually means.
Do you have to pay your income taxes? No, you do not.
Do you have to be faithful to your significant other? No, you do not.
Do you have to retune your motorcycle if you install an unknown combination of different air cleaner and/or exhaust systems? No, you do not.
As always, any decision always has both positive and negative repercussions.
Just because somebody did the mods without a tune, and notices no problems whatsoever putting on 172 miles per year going from bar to bar at 35 mph does NOT mean that the guy bombing up I-80 into the Rockies two up at 75 mph in August is going to have the same outcome.
Do your own research and make your own choices, because there are NO answers for you in these threads.
