primary bolt pattern
Old Mar 5, 2012 | 02:00 PM
hoglett's Avatar
hoglett
Stage I
Default primary bolt pattern
i need to replace my primary gasket and i know there is a pattern to tightening the bolts back but cant seem to rem it. is it like tightening the lugnuts on a car? i know you just dont tighten straight around!! Help please!!!!
Old Mar 5, 2012 | 03:13 PM
Puffdaddy's Avatar
Puffdaddy
Just remember a star pattern
I start bottom left, top, bottom right, left middle, right middle
Old Mar 5, 2012 | 03:14 PM
nvsteve's Avatar
nvsteve
Yeah, just use a crossing pattern and snug them up a little at a time. Not too tight!
Old Mar 5, 2012 | 03:21 PM
QehQeh's Avatar
QehQeh
No, it's not like tightening the lug nuts on a car. You're going to need a manual for your specific model.
Old Mar 5, 2012 | 09:36 PM
archergodwin's Avatar
archergodwin
Inner primary, outer primary... or derby cover?
If it's inner primary, you also need new bolts... but go with aforesaid star pattern.
Same on the derby.
Outer primary, just gradually increase the torque on each bolt in either clockwise or CCW direction... whichever, until you reach the torque spec. Like if the spec is 25"/lb, do the first round at 10.. next round at 20.. finish round at 25... (numbers used just for example).
thewoozel666
EVO
18
Mar 10, 2020 08:08 AM
CBCanada
EVO
21
Jul 25, 2016 01:17 PM
fighthedude
May 18, 2011 09:14 PM
blackfinbob
Aug 1, 2006 10:33 PM
jamesguynn
Sep 1, 2005 06:12 PM
