Cant get wires back into frame after drag bar install!!
I just installed some drag bars on my 99 wg,and Im having a real hard time getting the wires pushed back into the backbone/frame,They go so far and just bunch up and wont budge!!!! Is it just me or is there a trick to it?? I cant get to the bottom side or the end of it back where the battery is to pull em thru... Any suggestions,please!!!!
There may be a cable tie of some sort preventing them from going. I would pull them all out towards the front to see how much wire total you have...and then methodically attempt at folding, rearranging, and tucking them back in. There's quite a bit of room at the front of the frame, under the neck. Maybe you won't end up sliding them way back in the frame as much as folding them so they fit in the front neck area... Something to try nonetheless... Good luck!
not sure what year your bike is, but but on my 07 there is a big box of some sort, i am guessing a flassher unit in my wire area under the neck, I personally a fearing stuffing all mine back inside after i get my replacement molex connector body (i helped mine a little to hard, and was an idiot)one thing you may want to do is remove the plastic cap on the bottom of your backbone and try to re arrange the wires starting there.
The service loop is behind a rubber plug on the rear fender on my 2000 FXDX. You remove the belt guard to get access and then reach up under the fender. This way you can pull the harness rather than push it...
Awesome!!! I will def. try this thanks everybody!!!
With the frame change in 06 the newer bikes can be pushed and folded, 05 and older cannot. You have to pull from under the seat as you push into the neck.
You can do this without removing anything but the seat, it is especially easy if you have an extra set of hands.
