i finally put the newly painted tins back on, went great, no scratches, no dents..... Problem is when i went to check the rear lights, the turn signals wont blink, and the brake light wont come on, tailight works fine. and if i turn the alarm on, the signals work fine!!!!. also the speedo light does not work nor does the odo... but if i hit the trip button the odo lights and shows mileage..... ????? the horn doesnt work either, headlight works fine......im at a loss as to what the problem is.....
Maybe the TSSM? checked all the fuses, when i started the bike it fired right up but the red key light popped on......
everything i unplugged was a factory plug, and all of them went back together... I did remove the speedo to paint the Dash!!!!
Sounds like you mixed up some wires in the connectors if you disassembled the connectors. If you have a service manual I would go through the schematics and check everything you took apart. If you don't let me know what you did and I can scam the pages for you.
Thing is, i didnt even have to take any connectors apart.. Just unplugged the dash plugs, & rear fender harness.
Im freakin lost.... I started drinkin so i stopped workin on the bike for 2nite
