Exhaust
Old Apr 8, 2012 | 08:34 AM
Rodney54's Avatar
Rodney54
Default Exhaust
So I'm putting on my V&H big Radius 2-into-2 pipes and I seem to have ran into a road block. The front header fits great but the rear header is about 1/4 away from the bracket holes that came in the kit? I'm using my stock exhaust gaskets since the bike only has 200miles on them. Should I pull my stock gaskets out and use the ones they gave me? Its hard to explain but the rear header need to be moved ahead about 1/4 Im not sure how to do this. Any ideas?
Thanks
Rodney
Old Apr 8, 2012 | 08:48 AM
WideGlideFever's Avatar
WideGlideFever
Thanks
Rodney
It took a little bit of patience to get both of mine to fit in right also. Assuming you got the right exhaust for your year/model, it will fit; best thing to do is have a buddy with you so you can each work on positioning the headers at the same time. Good luck.
Old Apr 8, 2012 | 08:59 AM
ynots's Avatar
ynots
I have reused the same gaskets before without any leaks but if you already have new set Id use them, less chance of leaks. 1/4" sounds a long way off. like mentioned above get a helper and try aligning both flanges at once
triggerpuller702
Oct 2, 2014 07:47 PM
Landcruiser
Exhaust System Topics
Aug 18, 2014 11:56 PM
OldTyme
Jul 12, 2012 07:39 AM
zyban
May 13, 2011 08:25 AM
GringoLoco
Feb 25, 2008 08:43 AM
