The Plasti-Dip Thread
Old Jun 7, 2012 | 05:17 PM
  #171
128auto's Avatar
128auto
Thanks! Yeah I saw it on youtube, if you want a clean line, you must remove it before it dry out. Does it mean you can only spray one coating?
Originally Posted by HD7585
Yes I taped the edge i wanted with electrical tape because you can bend it in any shape you want.......covered the rest with paper and masking tape...........remember when you want a clean line you must pull the tape when the plasti dip is still somewhat wet..........if you let it dry ,the tape will pull off the plasti dip.
Old Jun 8, 2012 | 06:23 PM
  #172
Cprows's Avatar
Cprows
I did about 5 coats on mine. I let my mirror dry a little longer then the other parts and it started to peel off the plasti dip. Luckily enough the mirror is simple to re do!
Old Jun 19, 2012 | 08:17 AM
  #173
Homeboys On Harleys's Avatar
Homeboys On Harleys
Stage II
Just curious. I have been thinking about using the plastidip on my 883 tank and fenders. The tank however has the sportster logo that is glossed on and won't just peal off. Would I need to sand it down first and remove it, or would the plastidip cover it up pretty good. I want to replace the logo/emblem anyway.
Old Jun 19, 2012 | 08:24 AM
  #174
Mr.Guns's Avatar
Mr.Guns
Speaking from experience, it shows through. Unfortunately the only answer is to sand it down. I just did an 883 for a guy, and had to sand out the emblem. If you just spray over it, you can still see the outlines through it.
Old Jun 19, 2012 | 02:02 PM
  #175
Homeboys On Harleys
Stage II
Thanks PH, I appreciate the feedback. I may try this during the off season.
Old Jun 19, 2012 | 02:07 PM
  #176
hd2012's Avatar
hd2012
Here is a picture of mine....done the forks, battery box, heavy breather and detachable windshield hardware. Also done the crash bar.
https://www.hdforums.com/forum/membe...plasti-dip.jpg
Old Jun 19, 2012 | 02:14 PM
  #177
hd2012's Avatar
hd2012
Sorry...new to this...just figured out how to upload picture
  #178
hd2012's Avatar
hd2012
Old Jun 19, 2012 | 02:15 PM
  #179
gartec81's Avatar
gartec81
looks great. nice job
Old Jun 19, 2012 | 02:18 PM
  #180
hd2012's Avatar
hd2012
