Exhaust install...tools needed?
Old Apr 27, 2012 | 07:08 PM
sonnydaze's Avatar
sonnydaze
Originally Posted by Divinitus
Sonny, lube the nuts that hold in the head pipes or just all of them in general, like the bracket on the transmission, etc.
mainly head nuts but if you want do them all
Old Apr 27, 2012 | 07:09 PM
sonnydaze's Avatar
sonnydaze
Are the nuts on the heads somewhere between 45-60 lb's? Besides those, any other torque specs for any others?
Let me see if I have this right, o2 sensors disconnect from bike, not stock pipe before I remove them, then remove stock pipes. O2 sensors can go on new pipes before the are put on bike.
So basically, dig out old gaskets, put in new ones, using original clamps, insert pipes and keep everything hand tight until everything is in place, tighten to spec, connect o2 sensors, wipe down pipes, ride, then come home and check everything again and re tighten if needed?
no inch lbs
Old Apr 27, 2012 | 07:46 PM
p51bombay's Avatar
p51bombay
45 is barely even tight - they are 120 inch/lbs
Old Apr 27, 2012 | 07:48 PM
maddghost's Avatar
maddghost
Which is 10 ft lbs, they don't have to be tight.
Old Apr 27, 2012 | 08:53 PM
Divinitus's Avatar
Divinitus
Another thread post in this claims 60-80 inch on the head bolts, that sound right?
Old Apr 27, 2012 | 08:56 PM
Divinitus's Avatar
Divinitus
The above info was pulled from another thread where poster claims he took that straight from the manual.
Old Apr 27, 2012 | 09:01 PM
nevil's Avatar
nevil
Another good reason to get the manual for your bike so there won't be any question about specs.
Old Apr 27, 2012 | 09:26 PM
p51bombay's Avatar
p51bombay
section 4-35
100-120 in/lbs
Old Apr 27, 2012 | 11:44 PM
Divinitus's Avatar
Divinitus
Thank you for posting this. I will be getting a manual, but I was going to try this tomorrow after I get out of work tonight and want to have all my ducks in a row.
Old Apr 28, 2012 | 12:15 AM
ynots's Avatar
ynots
search around online for the installation instruction, usually will find them in a .pdf format. some styles of pipes can be tougher than others
Rise_
Aug 12, 2019 01:45 AM
dontdropit
May 16, 2016 07:38 AM
TedMan
Feb 18, 2012 03:50 PM
jnorbros1
Jan 24, 2012 08:35 AM
PghSerb
Aug 14, 2011 12:01 PM
