Installing new risers, the right torque value feels to soft?
Old May 4, 2012 | 01:37 AM
onemyndseye's Avatar
onemyndseye
Originally Posted by 128auto
Don't over tighten them, you might end up stripping the threads. Helicoil them, I did mine, last forever.
+1
Torque values are your friend. I once did a nice job of removing the threads from a riser using a grade 8 bold XD
Old May 10, 2012 | 05:11 AM
7mag's Avatar
7mag
I just found this on another thread when I was googling to see if there was a tightening sequence that is needed for tightening the bar clamps and riser bolts,
"It's not in the bushings.. It's in the sequance you tighten the Bar top Clamp.. Tighten front Fasteners to just hold the bars in place, Tighten rear fastners to 12-15 Ft-Lbs Final tighten front fastners to 12-15 Ft-Lbs ..There shopuld be a gap in the front....Then Torque the Riser Bolts to 30-40 Ft-Lbs.."
I just spent the last hour searching the forum trying to find this thread again as the search function seems to on the fritz.
Old May 10, 2012 | 07:17 AM
jcmusic's Avatar
jcmusic
I had the same issue with my 04 LR a few years ago, I went over everything again used the torque spec and all is well. Just tighten the riser bolts last.
Old May 10, 2012 | 08:39 AM
p51bombay's Avatar
p51bombay
For anyone that thinks proper torque isn't important, have a look at what can happen.
Old May 10, 2012 | 09:04 AM
Krazy8s's Avatar
Krazy8s
That's some scary ****.
Glad this thread reminded me to get new bushings and bolts for my ape project next month.
Old May 10, 2012 | 02:45 PM
7mag's Avatar
7mag
Agreed that is some scary Sh*t, I am going to re check all mine now before a take the bike anywhere.
jake.mason.2
Milwaukee Eight (M8)
Oct 8, 2018 06:41 PM
thoner7
Apr 30, 2013 07:16 AM
Harold Coltrane
Mar 21, 2012 06:51 AM
meatpunch
Aug 12, 2011 08:22 PM
MNrider
May 2, 2009 08:09 PM
