Project FXDXT is underway
Old Aug 2, 2012 | 10:03 AM
  #361
Good_Apollo's Avatar
Good_Apollo
Originally Posted by Hogpro
All I know is now my gas mileage is about 33, really low. fI guess I'll find out the specifics of what was done to the engine if anything when I do the 95 kit. I'm imagining my mileage wills till be better than it is now. What did you do for jetting on your Mikuni? Anything?
Well, I had the motor built and tuned and the Mikuni all put on at the same time. I am sure they switched out jets. I pulled my plugs yesterday and the color was perfect, my engine runs cool and I get about 40mpg on average. They really did a good job with the tune. Can't complain about 40mpg with my HP and TQ numbers.
Old Aug 2, 2012 | 10:17 AM
  #362
Hogpro's Avatar
Hogpro
Former Sponsor
10:5:1 is too agressive for my taste but if I get close to 100/100 I'll be super happy. Suggestions for heads? I am thinking of either the Harley exchange for their heads or the Branch O'Keefe exchange which costs about $200 more. I am planning on a relatively low compression build compared to yours. 9:6:1 or 9:8:1. All suggestions will be considered so give me some advice guys as engines are definitely not my specialty.
Old Aug 2, 2012 | 10:24 AM
  #363
Good_Apollo
I was in the same boat, I can work on motors but have no clue about building them for performance. I just took the builders advice, although they went with cams that were too aggressive for me, originally had S&S 640s in there, I had them swap them to 585s. My heads were ported in-house by the guys who built my motor. I have heard good things about Big Boyz though, not sure if they do swaps. Fuel Moto does head porting as well.
Old Aug 2, 2012 | 06:08 PM
  #364
Danofxdx's Avatar
Danofxdx
Hogpro I had the stock windsheld, changed to the Cee Baley 11" wind deflector and it was not enough protection, I now have the Cee Baley 14" dark gray and it is perfect glad I did not go with the blacked out one. this is a stock SE 103 Kit and it had the flat top pistons but I don't know what the CR is but with the easystart cams it spins right over with the stock starter when I get back in town I will do some really acurate MPG readings with the S&S G and then the CV 44 and see what I come up with, might take her out for a long ride on the highway tomorrow and see if I can get some numbers before I put her away. I'll keep you guys posted 800 miles since the rebuild so she is pretty much broken in!
Old Aug 3, 2012 | 09:34 AM
  #365
Hogpro's Avatar
Hogpro
Former Sponsor
As far as the shields are concerned, Rifle makes on that is a bit wider than the stock width but I opted for the Cee Bailey's as I wanted the stock width. Hindsight being 20/20, I might get even better wind protection with the wider shield but I like what I have for now.
Gonna research some S&S heads this weekend and see if that might be a better option. My stock heads I have off my other ride have 60K miles on them soa rebuild would be necessary in my opinion and if I am going to spend cash on that I might as well get some really nice good quality heads while I am at it. It might be a bit till I figure this motor bit out.
Old Aug 3, 2012 | 09:49 AM
  #366
Wakko47's Avatar
Wakko47
Every time I look at your front wheel I think that front tire looks backwards. Is it?
I'd never have thought the canvas VRod bags would look good...but they do. I say leave 'em!!!
Old Aug 3, 2012 | 09:59 AM
  #367
07bobber's Avatar
07bobber
what happened to big boyz doing your heads? even if you rebuild them it would be cheaper than going with S&S or other big names...
Old Aug 3, 2012 | 10:27 AM
  #368
Hogpro's Avatar
Hogpro
Former Sponsor
Yeah but with dealer cost it will be very close to the same. Once I add in shipping to Maine and all, pricing is so similar that it's a better option.
Old Aug 3, 2012 | 10:01 PM
  #369
floridamk's Avatar
floridamk
[QUOTE=Wakko47;10157872]Every time I look at your front wheel I think that front tire looks backwards. Is it?
I just installed the michelin commanders on my bike and sat there through two cold beers scratching my head.
The arrow on the sidewall shows the correct rotation!
Old Aug 4, 2012 | 12:55 AM
  #370
Wakko47's Avatar
Wakko47
So yours look like Hogpros? I'd think the tread would strike the ground in the middle and push out, not the opposite.
