Project FXDXT is underway
Old Aug 31, 2012 | 03:38 PM
  #461
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by Hogpro
I think I am ordering and HID today. I can hide the ballast in the fairing somewhere. I finally got my DK Custom products Stealth bobber air cleaner installed last night. I love the breather bolts and after a test ride in this morning it seems there is no oil coming out of them at all which was a concern. I think it looks great but ordered some other covers as well so I can compare and contrast the looks. Once I get the others mounted I will post pics and ask for your opinions as mine are not always the best. I did manage to lose the polished stainless and brass nut for the cover in the last few days so i used a 1/4 20 bolt I had laying around with an ugly *** washer. It will do until I locate the stuff that came with the kit. The cover is black although it may be a bit difficult to tell with the sun shining right on it.
Looking good man.
Yeah, the sun can play havoc taking pictures...wait til you start snapping pics of the chrome one. lol
btw, today is the last day of the 10% savings on the OUTLAW A/C's
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Aug 31, 2012 | 04:36 PM
  #462
Fxdxt-I's Avatar
Fxdxt-I
Hog pro how did you mount those bags?
Old Aug 31, 2012 | 04:43 PM
  #463
Hogpro's Avatar
Hogpro
Former Sponsor
I just got the bushings for mounting them yesterday. I am going to get it done this weekend. I'll have pics come Tuesday.
Old Sep 4, 2012 | 10:14 AM
  #464
Hogpro's Avatar
Hogpro
Former Sponsor
Ok, I figured out why the back plate for the a/c broke. The Mikuni sticks out further than the stock carb which put extra stress on the bracket for the breather bolts. So , I have spaced out my DK Customs a/c a little further with a few extra washers.
On to the weekend projects. I got my FXR bags mounted up on the bike on Saturday and I really dig them. They are definitely vintage looking as they have been used. I first mounted them with the qd brakets for the sissy bar. I then decided to take the docking points for the qd brackets off so the bags would sit closer to the struts. Sorry, no pics with the qd hardware on. I dig how these bags actually line up perfectly with the shocks and such. They also have plenty of space.
I then mounted up the police radio box mount for my radio box. I was not sure it was going to fit over the passenger portion of my seat but lo and behold it barely did. I never got around to getting the box mounted up as I had planned to do.
Next I put on a bunch of different air cleaner covers that I ordered from DK Custom products to see which I liked best. I could not decide so I need some help from you guys here. Let me know which you like best please.
After riding with this air cleaner for a few days I really dig it. Nothing has come out of their killer breather bolts and it is slimmer than a big sucker or any other a/c I have had so it does not hit my knee when my feet are on the forward controls.
But wait, I'm not done yet. I rode over to a buddy's house and started tearing the engine down for the 95" build next. I'll start another posting to explain that for those who are interested in what all is involved. I'll be going over after work for the next few days until it is completed.
Yes I have been busy.
Old Sep 4, 2012 | 11:19 AM
  #465
Hogpro's Avatar
Hogpro
Former Sponsor
The first thing to do for the engine build was to tear everything down. I pulled the seat and set to work. The exhaust came off next. I didn't take nearly as many pics as I should have to document this but feel to ask any questions you have and I will be glad to answer.
Next was the intake manifold for which I got a tool from the fatbook (Drag Specialties) to assit with. I had been using a cut down allen wrench which was still a pain in the butt. Once you get the manifold bolts out unplug the sensor plugged in to the manifold. Set it aside with all of the other stuff. I use the boxes that my new parts are coming out of for the bolts and such as I know which bolts go where but it always a good idea to bag and tag if you are concerned about getting them mixed up.
Next I pulled the bolts for the right footpeg and rear brake lever. I put these bolts right back in the frame so that I know where they are when I need them.
Next was the tank. I used two vice grips on either side of the fuel line to clamp it off and cut the fuel line in the center. I lost a few drops of gas but that was it an the rest was drained into a gas can afterwards. Then was the rocker box covers. My bike had the hot toppers on the rocker box cover bolts. I used a small screwdriver to pry them off. Into the box with the rest of the bolts thus far. I then removed the 6 bolts on each rocker box cover and set them aside. I slid off the rocker box covers keeping front and rear in different areas so I know which came from which not that it really matters.
http://i1021.photobucket.com/albums/...t/IMG_4462.jpg
Next I removed the breather bolts and the rocker bolts and set them aside in the front and rear piles. On the the lower rocker box cover bolts. Pull them and set aide with the uppers. Next I pulled my pushrods out from the top although I have adjustable as I am disassembling everything anyway. I then pulled the clips off the push rod tubes and pulled the tubes. Next were the head bolts. Once they are out tap the heads with a rubber mallet and set them aside.
Now you can pull the cylinders off. I did not need to tap them with the mallet. they came right off. On to the cam cover. Before all of this I drained the crank case oil as well. Pull the cam cover bolts. Put the drain pan under the cam cover to catch any excess. If you are super **** wrap the frame with plastic, but I never bother.
Next for the cam plate. and lifter blocks. Once the cylinders are off I pull the lifter blocks as it is easiest to get at the rear bolts for them without the cylinders on the bike. Once the blocks are off pull the pin and then the lifters and set aside. I was concerned that the lifters might have some wear on them but they did not. Next for the 10 bolts that hold the cam plate and the oil pump. More oil will come flowing out once the oil pump bolts are removed. Once all the bolts are out slide off the cam plate and then the oil pump.
Since I already have the new s/e upgraded plate and pump on my bike there is no need to change any of these parts. I also replaced the inner and outer bearings 5000 miles ago so I am not going to replace them again. I checked them all and they are fine. Once the cam plate and oil pump are out I have removed everything necessary with the exception of the pistons.
Old Sep 4, 2012 | 12:33 PM
  #466
DanDman's Avatar
DanDman
How many different bags do you have now? I've got mine torn apart. Only doing camplate,& cams. My big bore is going in my Road Glide. Can't afford to do both right now. Great thread by the way!
Attached Thumbnails Project FXDXT is underway-101_0682.jpg   Project FXDXT is underway-101_0680.jpg
Old Sep 4, 2012 | 01:08 PM
  #467
Hogpro's Avatar
Hogpro
Former Sponsor
I have 3 sets of bags. I am giving one set to a buddy and the other set are taking up space. My wife is laughing as she said I might now understand what it is like with women and purses now.
Old Sep 4, 2012 | 01:44 PM
  #468
oaken1's Avatar
oaken1
either of the diamond plate covers looks nice...kinda prefer the black one on this bike.
Old Sep 4, 2012 | 02:19 PM
  #469
EastBay_Solo's Avatar
EastBay_Solo
I am thinking about selling off the TH and getting a fatcat. Who knows.
Ive had a fat cat for over 3 years now with no issues. Its a great pipe and will handle just about any mods you do. Ive also had a thunder header as well great sound, shitty finish . Good luck bro love what you have done to the bike so far.
Old Sep 4, 2012 | 02:25 PM
  #470
Hogpro's Avatar
Hogpro
Former Sponsor
The fatcat has been on for several months now. No issues and the fit and finish on this pipe is incredible. I also really like how the pipe itself is black, the heatshields are black, and the flanges are black as well. The black is also a much darker black than some of the manufacturers black. The TH was kind of brownish as are the V&H competition series. There has been no fading on this pipe at all. Fine work by D&D. The quiet baffle is good as it does not wake the neighbors at 6am as do the pipes on my other bikes.
