Project FXDXT is underway
Old Sep 9, 2012 | 07:13 PM
  #481
07bobber's Avatar
07bobber
so how many miles u at after this weekend?
Old Sep 10, 2012 | 10:56 AM
  #482
Hogpro's Avatar
Hogpro
Former Sponsor
I got my 500 break in miles done this weekend. Got home from my ride yesterday and dumped the oil and swapped filters. I was able to open the bike up on the way to work at 6am on the 405. Surprisingly there is still quite a bit of traffic at 6am but i was able to get to a "safe" location and whack the bike in various gears. This thing has some get up and go. I also took it for a test ride after the oil change last night on the 10 freeway. I think this will keep me happy for quite a while and would recommend this mod to anyone.
I got my heads, cylinders, and Pistons from Dunn Performance out of Colorado http://www.dunnperformanceheads.com/ and everything went together great although the cylinders needed a little extra help going over the piston rings. I think it was my cheap *** ring compressor. I replaced my Andrew's 26 cams with their 37 model. Already had the cam plate upgrade, new bearings etc.
This motor is tight and quiet. It moves quick. I am glad I didn't do any more than this as it is plenty for my needs. No need to roll at 100 on a daily commute but it sure is fun for a split second. The break in was torture trying to keep the bike down around 2500 rpms for 500 miles. It some serious will power which I have little of. Am I going to Dyno the bike now? I don;t think so. I did adjust the AFR a little to try and eliminate a bit of decel popping and all it did was move the popping from on RPM to another. I think I need to put the needle on the second clip in the carb next time I have it off. I didn't do compression releases and time will tell if my starter has what it takes to hold up of if I need to do that as well. My compression was supposed to 9:8:1 but I used the 95" kit stock head gaskets which are .045 and b umped the compression down to 9:7:1 or so. That will be just fine for my need for longevity.
Knowing myself I will most likely not be able to leave it alone anyway.
So am I happy? I think so. Next is to get the box mounted and painted but I think I'll take a few weeks off of working on the bike and just ride it. It sure is fun! I even had time to give it a bath in between my 450 miles this weekend. The rest of my 500 miles were accumulated commuting.
Old Sep 11, 2012 | 09:53 AM
  #483
Hogpro's Avatar
Hogpro
Former Sponsor
This thread sure has gotten slow, unlike the bike. Any feedback on the a/c covers that I did not get yet? Maybe I should start a poll to get everyone's opinion?
Old Sep 11, 2012 | 10:27 AM
  #484
Hogpro's Avatar
Hogpro
Former Sponsor
I got a black anodized wheel powder coated with a candy black which is really a sort of grayish color. The pc job is not so hot and I am not sure on the color. The black has turned to a sort of purplish like anodizing that has been in the sun. It looks similar to my front rotor carriers which sit in the sun for a good portion of the day most days. I really dig the gray where the raw aluminum was but need some feedback from you guys. Thoughts?
Old Sep 11, 2012 | 11:34 AM
  #485
07bobber's Avatar
07bobber
get it it redone in solid black...what size is it?
Old Sep 11, 2012 | 12:03 PM
  #486
Hogpro's Avatar
Hogpro
Former Sponsor
19x2.15. I'm not sure what I'm going to do with it yet.
Old Sep 11, 2012 | 03:40 PM
  #487
RJM52's Avatar
RJM52
Hey...we are just kicking back and enjoying your project...you generally spell everything out so clearly there aren't a lot of questions...but more pics would be nice...
I voted "find another air cleaner cover"...none are worthy of your build...
Bob
Old Sep 11, 2012 | 03:44 PM
  #488
Some_Punk's Avatar
Some_Punk
Re-powder the wheel, black. Just black.
Old Sep 11, 2012 | 03:46 PM
  #489
Hogpro's Avatar
Hogpro
Former Sponsor
As far as the a/c I really dig how narrow it is. The other a/c that was on there really got in the way of my knee when I put my feet on the highway pegs. I think that an RSD turbine would look killer in a black ops or contrast finish but I'm sticking with this one for now. Gotta replenish the bike fund after the motor build.
Old Sep 11, 2012 | 06:22 PM
  #490
Guest
Guest
Posts: n/a
I'd PC the wheel gloss black. Good looking wheel by the way.
