Saddle Bag Bracket?
Old May 17, 2012 | 10:13 PM
Blakerea's Avatar
Blakerea
Default Saddle Bag Bracket?
I have regular harley leather bags on my bike similar to these. Saddle bag. Is there a set up that i can make these detachable? Is there a bracket for them?
Thanks
Old May 17, 2012 | 10:36 PM
xantasm's Avatar
xantasm
If you used the search tool you would find that subject has been discussed several hundred times on here but I'm in a good mood after dinner at Olive Garden so I'll be nice and give you some links to get you in the right direction.
http://www.edgeleather.com/
http://www.ghostbrackets.com/
http://www.kuryakyn.com/Products/386...arleys#Bracket
Old May 18, 2012 | 12:30 AM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
I don't know how those bags mount, but I mounted mine w/threaded rod IOT easily take em off for cleaning. It's the only time they come off.
Old May 18, 2012 | 11:53 PM
JimmieJack's Avatar
JimmieJack
I also did something similiar to threaded rod - I put a long bolt from the inside of the fender out. I put a flat wsher and 3/8 wingnut on it marked it and cut it as short as I could. I also drilled a real small hole through the bolt so that I could put a retaining clip on - so the wingnut can't work itself loose. Pretty much just take the bags off for cleaning (or maint.)
Jimmie
BearHawg
Jan 8, 2013 08:55 AM
Mal74
Jun 16, 2012 04:13 PM
Slipperysam
Aug 27, 2009 02:39 PM
went_postal
Dec 12, 2006 05:21 PM
bassrock
May 6, 2005 02:25 AM
