Rear brake master cylinder
Old Jul 3, 2012 | 05:03 PM
junkyardscrounger's Avatar
junkyardscrounger
Default Rear brake master cylinder
I think whoever designed this bike should be shot for not making a extended fill for the rear brake master cylinder,I am going to see if the aftermarket has a fix for this as it was a pain to add brake fluid and glad I did not have to do it on the road.
Old Jul 3, 2012 | 06:07 PM
rdondes's Avatar
rdondes
Just buy a $1.99 turkey baster from the local supermarket. Easy to add/remove brake fluid from the rear master cylinder. The design is crap - I agree. But there's no need to spend lots of dollars to fix a problem that can be fixed for $1.99.
Old Jul 3, 2012 | 06:41 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I bought a "ketchup" squirt bottle and put a piece of hose on it to service the rear resevoir. My bitch is getting to the hardware to remove the cover.
Old Jul 3, 2012 | 08:47 PM
junkyardscrounger
I had a hard time getting to the screws and putting the cover back on was not much fun too.
Old Jul 3, 2012 | 09:16 PM
BluBob's Avatar
BluBob
Veterinary syringe with a piece of clear tubing on it. Big one, like 30 or 50 cc I think. If the tubing is the right size you can use it on the bleeder nipple too.
Old Jul 4, 2012 | 12:08 AM
jp28's Avatar
jp28
I bled the rear brake caliper today and I completely agree about removing the screws, especially the forward one.
Old Aug 16, 2012 | 09:13 AM
byronand's Avatar
byronand
Stage III
How DO you unscrew the cover? I don't see how to get a philips screwdriver down in there.
Old Aug 16, 2012 | 09:37 AM
Some_Punk's Avatar
Some_Punk
Craftsman makes these little ratchets, about 2 inches long that take screwdriver bits and they're angled out of the box. That's what I've been using for a while and it's awesome.
Old Nov 20, 2020 | 07:51 PM
Boy_Fat3's Avatar
Boy_Fat3
6th Gear
hey I found this I need to flush out the brake fluid on my wifes new to us 2012 Dyna super glide...........Do you have a photo of the wrench ? or a model number...cause it sounds like its what I need to get the cap off without taking pipes loose. PS I know this post is old but I thought it would be worth a shot to try ?
Old Nov 21, 2020 | 02:41 AM
kidmo's Avatar
kidmo
Here's a couple I found at Lowe's and also at Amazon
Stampy167
EVO
35
Jul 16, 2015 08:29 AM
harley7316
Sep 15, 2014 04:20 PM
Steen
Jan 29, 2014 06:23 AM
mrmeanbean74
Apr 30, 2010 04:33 PM
aharley1
Jul 1, 2008 07:03 PM
