Rear foot peg removal
Old Jul 4, 2012 | 05:43 PM
bjv11383's Avatar
bjv11383
Default Rear foot peg removal
When the rear/pax foot pegs and mounts are removed on a Fat Bob...what can be done to fill the holes?? Or just leave the holes alone after they are removed?
Old Jul 4, 2012 | 05:45 PM
nkauf21's Avatar
nkauf21
You can get little black plastic plugs from HD that pop into the holes.
Old Jul 4, 2012 | 07:33 PM
ynots's Avatar
ynots
you could cap them with short bolts to keep water out. superglides come with the plastic plugs in the holes
Old Jul 4, 2012 | 08:51 PM
dynagliding's Avatar
dynagliding
if you still have the belt guard on you will need a bracket because the guard is connected to the rear peg
Old Jul 4, 2012 | 09:01 PM
AFMM3's Avatar
AFMM3
I cut my left rear peg mount off at the belt guard mounting point. The other side can either be filled with the original bolts or the plastic plug. Once again, I cut mine off and attached an old style tool box to it.
Old Jul 4, 2012 | 11:35 PM
bjv11383's Avatar
bjv11383
Thanks! Plugs sound good to me. I got the belt guard covered.....I plan to remove both pegs and replace peg mount on belt guard w/ different bracket from another dyna.
Old Jul 5, 2012 | 12:38 PM
bjv11383's Avatar
bjv11383
Anyone got the P/N for the plugs that are being mentioned??
Old Jul 5, 2012 | 12:44 PM
nevil's Avatar
nevil
When I need those plugs I go to Ace Hardware. It's a lot closer to me and I have a feeling they are cheaper than the HD parts.
rockydog53
Sep 19, 2016 09:14 PM
Red_Haze
Jan 7, 2016 05:44 PM
jwlehman
May 23, 2010 03:13 PM
drhooligan
Nov 11, 2008 11:47 PM
waffler
Sep 10, 2006 08:54 PM
