electrical problem
Old Jul 30, 2012 | 10:29 AM
slider1156's Avatar
slider1156
Default electrical problem
09 FXDF fat bob with security, turn off bike blinkers flash, then a few seconds later some of the lights on the speedometer flash, oil pressure and high beam, lights on the speedo flash, its keeps doing this. I pulled the main fuse and let it sit for a few and put it back in, and its starts doing the same thing. Security module going bad? The Security LED should blink like that not the whole speedometer. Can I take the security module off and the bike will run? I have changed to a different speedometer, H.D. unit with a tach but that was a year ago and have had no issues.
Old Jul 30, 2012 | 12:13 PM
slider1156's Avatar
slider1156
Ok went out at lunch and messed with it again. When the blinkers flash the cluster lights up and the fuel pump pulses. I pulled the ecu fuse and it still does it. so its something besides the ecu. When you start it all is good. Time to get it home and pull out the schematics. Anyone ever had this problem. I am thinking alarm module and or ignition switch
Old Jul 30, 2012 | 12:18 PM
nevil's Avatar
nevil
There is a way to reset the security module (TSSM). Try searching for it. Other than that I can't say what to do next.
Old Jul 30, 2012 | 05:05 PM
slider1156's Avatar
slider1156
Any one else have any other ideas???????. I just had a rear fender replaced under warrenty but all seems to be ok with the brake lights etc.
Old Jul 30, 2012 | 06:05 PM
lo-rider's Avatar
lo-rider
Check your mods. Buy the service and parts manuals.
Old Jul 30, 2012 | 06:35 PM
hddan502's Avatar
hddan502
Look for a relay if you have the electrical schematic. In a car I had blower fan would not turn off. I puled every fuse that said ac/heat and the fan would keep blowing all at one time. I could not find the relay,mechanic informed me that is what it was. It was just stuck/welded in the closed position. I do not know for sure but worth a try.
Old Jul 31, 2012 | 10:22 AM
slider1156's Avatar
slider1156
I have a service manual since I am looking at the wiring diagram lo-rider. That seems to be your usual answer. After troubleshooting it turned out to be the run-stop-turn module that makes the blinkers work as brake lights. Removed it and everything works fine.
Old Jul 31, 2012 | 10:37 AM
lo-rider's Avatar
lo-rider
So it was your mods.
Old Jul 31, 2012 | 12:04 PM
slider1156's Avatar
slider1156
yep circuit board was full of water, crappy harley seal job.
Old Jul 31, 2012 | 05:43 PM
lo-rider's Avatar
lo-rider
Glad I could help.
That's my other usual answer (check your mods).
flatheadknucklepanshovel
May 14, 2017 11:54 PM
Inkdwheels
Dec 13, 2012 10:44 PM
RUSH_MC1
Jun 27, 2012 11:58 AM
ChristoHD
Apr 19, 2012 02:55 PM
grimm
13
Jul 1, 2005 04:42 PM
