will just doing cams make a difference?
Old Aug 5, 2012 | 07:01 PM
JohnC FXDX's Avatar
JohnC FXDX
Originally Posted by sickboy75
i do mostly two up riding, where did u get the kit that cheap? cheapest i seen was 999.99
If you use your own cylinders, you can do it for even cheaper than that.
Old Aug 5, 2012 | 07:12 PM
perki48's Avatar
perki48
You will get more out of "just a cam" than you will out of "just a bore". And you don't have to tear the top end down.
Old Aug 7, 2012 | 07:25 PM
ilovemyskidoo's Avatar
ilovemyskidoo
I also doo mostly 2 up riding i went to this site http://www.cyclepartsforless.com and i typed in this part number 29893-07b and they had it $630 shipped to my door.
Old Aug 7, 2012 | 10:10 PM
Kaycee's Avatar
Kaycee
I just did 26's in my 05 WG for $460 I found the cheapest price for cams was direct harley parts.com.This total allso included a 07 cam plate/pump(used) I wanted to upgrade to the hyd. tensioners and oil pump,plus I found a set of adj. pushrods here on the parts board for about half of new and yes they were new.Did all the work myself not to hard if u have any kind of mech ability.Power is better got some throttle when U need it ,but not a neck snapper
Old Aug 7, 2012 | 11:21 PM
ackman1968's Avatar
ackman1968
I have 26H's in my otherwise stock 88 and it woke it up, works fine solo and two up. I bought mine new off ebay from a guy that bought them then changed his mind. Got them new for under 200 to my door.
Tex Bill CC
Aug 5, 2010 01:30 AM
creep1
Apr 15, 2008 10:33 PM
mikeboztx
Feb 29, 2008 09:58 PM
dg7080
Exhaust System Topics
Sep 11, 2007 08:12 PM
Meathooks
Jan 23, 2006 07:53 AM
