Question on Jetted carb
Old Sep 4, 2012 | 02:11 AM
Funky Monk's Avatar
Funky Monk
Originally Posted by 3408pete
put your finger in the pipe and see how it compares to the front pipe in wetness and thickness of the build up.The cylinder could be starting to go away guide wise as well as ring wise .I would think about a leak down test on the cyls as a way to put my mind at ease.
Is it common on an engine with only 6,000 miles? My problem is I'm a car guy so I'm going to ask a few questions, how do I turn the crank with no kick start to get top dead center on compression stroke? Don't want to dig around removing stuff to do so. what do you suggest? Also I don't really trust any professionals to do it for me. Thanks Pete.
Old Sep 4, 2012 | 06:08 AM
fxrider03's Avatar
fxrider03
6th Gear
jack up rear tire put it in high gear turn tire
Old Sep 4, 2012 | 07:25 AM
Funky Monk's Avatar
Funky Monk
Unhappy
Thanks rider. Thought about this from the get go but need to lift it safely and stable, guess I'll be getting the jack stand sooner then later.
Old Sep 4, 2012 | 08:20 AM
3408pete's Avatar
3408pete
to answer th 6000 mile question I have had motors lay down around the 4000 range its like anything else if you are running them hard with lots of rpm and heat.
pull the plugs when that you are turning the rear wheel it will make it easier
Old Sep 4, 2012 | 09:38 AM
Austin Dave's Avatar
Austin Dave
The two best jacks are the J&S and the PitBull. Both made in the USA. Each is well-made, safe and have great warranties. Then there are rip-offs of those brands that are made in china (suspect/cheap hydraulics). I found a J&S on CL.
Old Sep 5, 2012 | 08:20 AM
Funky Monk's Avatar
Funky Monk
Thanks guys, getting a chance to check at least the compression this morning. Waiting for a leak down tester to arrive some time next week. I'll post the readings soon. Thanks Dave Going to get the J&S jack.
dynarider77
May 5, 2018 10:39 PM
TroyCreese
General Topics/Tech Tips
Jun 23, 2017 04:47 PM
Delawaredave
EVO
24
Jul 2, 2014 04:55 PM
JZscoot
Ironhead
Jul 2, 2009 12:48 AM
wolf1477
Ironhead
27
Jun 3, 2006 12:54 AM
