Will I need a load equalizer?
Old Nov 17, 2012 | 06:42 AM
vdop's Avatar
vdop
Originally Posted by Notgrownup
So it lowers the load because if the load is higer it will be too much power going to the signal and make them flash faster...??? is that right???Make sense because LED use almost no current...
Basically that's the idea. LEDs don't provide enough resistance.
Originally Posted by Fusion777
The load equalizer that ships with Panacea is not so good. The documentation warns you that ro NOT run 4-way (I.e. hazard) blinkers for extended amounts of time, or the equalizer will overheat. Serious fail. Also for dyna 06+ its now one switch instead of 2 so you either get:
- integrated turn signals + flashing brake light
Or
- no turn signals + solid brake light
Also disappointing. I will be getting a replacement equalizer at some point, maybe it will provide integrated signals+solid brake light. Here's to hoping
The most recent panacea I installed was on a newer dyna and it had the option for integrated signals with a normal brake light like you want. Not sure why yours doesn't.
Old Nov 17, 2012 | 11:35 AM
Fusion777's Avatar
Fusion777
I agree it's weird. I even confirmed it directly with the manufacturer. If its important to you this feature i would definitely call them before ordring.
pike40
Jun 9, 2012 09:48 PM
METALKAT
Apr 10, 2010 06:26 PM
bullseye
Dec 29, 2008 03:29 PM
LeadSlinger0311
Apr 11, 2008 10:39 PM
2007fxdc
Apr 1, 2008 08:39 PM
