Bagger Dual Exhaust on a Dyna
Old Dec 12, 2012 | 10:06 PM
blackv03's Avatar
blackv03
Default Bagger Dual Exhaust on a Dyna
I've only seen one picture of an old FXR with dual exhaust that exited on each side of the rear tire .. and I have to say it looks badass !!! has anyone else tried this on "newer" Dynas? I have an 03 Lowrider that I'd love to have true duals on. Someone out there must have tried this ... right??
Old Dec 12, 2012 | 11:27 PM
SURFOR Chop's Avatar
SURFOR Chop
Forum member AFMM3 has adapted an '09 Touring exhaust to his Street Bob ...
There are a couple of hurdles that have to be cleared in order to do this modification ...
Although the motors are both "A" type (i.e., not counterbalanced like the "B" variant in Softail models) and therefore the exhaust ports are mirror images ... the mounting position/orientation of the motors is slightly different between the the Touring and Dyna models ... the Touring are rotated slightly forward with respect to the crank axis or it could also be expressed as the Dynas being rotated slightly to the aft ...
I adapted a Touring pipe (Paughco) ... and before modifying it, the pipe fit, but it angled down to the aft ... I took it to a muffler shop and asked them to bend it a few degrees more ... then had the rear pipe cut down about 3/4" ... got it to hang horizontal ...
Going with a dual exhaust with the crossover the big issue is how to support the muffler on the left side of the bike (well, both sides, actually) ... the Touring models support the mufflers on the saddlebag brackets and you can't really do that with the Dyna ...
Also, the Softail solution for supporting the dual mufflers doesn't really work since the Softails use the frame ... well, the Dyna motor is rubber mounted so you can't mount the exhaust from the frame on the Dyna or the vibration will beat it apart ...
Here's a photo of mine with non-dual ...
Here's a link to another thread where AFMM3's technique is detailed on pages 6 and 7 ...
https://www.hdforums.com/forum/dyna-...low-rider.html
Hope this helps ...
R/
'Chop
Old Dec 13, 2012 | 05:25 AM
AFMM3's Avatar
AFMM3
Vance and Hines does make a dual exhaust for the FLD that could be adapted possibly (anything is possible). Though at around $1,200 I have never heard of anyone purchasing it. As SURFOR Chop said, I made mine from a 2009 touring exhaust. In the first iteration I suspended the mufflers from my saddlebag supports but I was wearing out the rubber isolators too quickly (every 800 miles or so). My second configuration includes a support bracket that gives each muffler support from the motor and the saddlebags are not required. Here is a YouTube to hear what they sound like.
Old Dec 13, 2012 | 07:59 AM
blueangel73's Avatar
blueangel73
I have been trying to figure this out for awhile now. I have also been following Chop and AFMM3 for awhile with their progress. I will start watching this thread also to see if it goes anywhere. Good luck!
Old Dec 13, 2012 | 07:03 PM
AFMM3's Avatar
AFMM3
OK, I will make it even worse for you blueangel73, here is my father's 2005 Super Glide/70s FLH Clone. I am not sure if he finished yet but he is also doing dual exhaust. From what I remember, he told me that the fron down tube is the stock Dyna graphted to a Twin Cam 2005 FLHT right side exhaust. The left side exhaust pipe was from a Shovelhead FLH. I think he was down to working out the muffler bracketry when he got distracted by his Shovelheads. He will probably finish it up next month or so.
Old Sep 2, 2013 | 08:49 AM
Homeward Bound's Avatar
Homeward Bound
Any one tried it the other way around?
Dyna dual pipes and mufflers on a FL bagger like a Road King?
Old Sep 2, 2013 | 03:05 PM
sonnydaze's Avatar
sonnydaze
yes I put a set of v&h long shots on a ultra not to long ago . all I had to do was mod pipe mount off of transmission .
Old Sep 3, 2013 | 12:52 AM
sonnydaze's Avatar
sonnydaze
Old Sep 4, 2013 | 12:04 AM
HYPR's Avatar
HYPR
I love modding!
AFMM3, your Dad's ride is off the hook!
Bob
Old Sep 5, 2013 | 09:17 PM
Homeward Bound
Seems like a good way to clean up the back end for those who want their Road King to go "naked" or bagless.
07bobber
Jul 9, 2016 04:06 AM
jimhog
Jul 20, 2013 11:07 AM
sdfatbob
Mar 13, 2012 11:33 PM
coolmac
Apr 21, 2008 03:57 AM
