Motor problems!! HELP PLEASE!!
Old Dec 27, 2012 | 08:46 PM
  #91
Cruzn34's Avatar
Cruzn34
From: American by Birth, SOUTHERN by the Grace of GOD!
Oh I plan to post a complete review of everything after the problem is found! It may help,someone else and maybe keep someone from spending too much cash for items that don't need replacing like I have done! Thanks again soft!
Old Dec 28, 2012 | 05:09 PM
  #92
Cruzn34's Avatar
Cruzn34
Checked tank vent line and I found no apparent blockage and even removed it and blew air through it. Cranked bike And it ran great with no problems, but I didn't get to run it down the road to test it under riding conditions! Too cold and rainy!! Will tear into the tank tomorrow and put the eyeball on the fuel pump lines, pickup, and filter! Guess that would be a good time to install a new filter! Anyway, I'll have a crackerjack harley tech in town from Monroe this weekend and my riding buddy will bring him over to take a look see! Anymore advice as to what I can look for is appreciated! When this bike is repaired, and it will be repaired, I will do a complete write up on the problem and fix! Thanks gang!!
Old Dec 28, 2012 | 05:14 PM
  #93
Cruzn34's Avatar
Cruzn34
Anybody ever had an ECM go out and if so, how did it act before replacing it?
Old Dec 29, 2012 | 06:40 PM
  #94
Cruzn34's Avatar
Cruzn34
Well gang, I finally got that Ugly Monster to rear its head and show me the problem!! Yessir, I had a Baptist minister, Catholic Priest, Jewish Rabbi, and a Buddhist Monk all gather around and attempt to Exorcise the demon in My bike!! First I want to take a moment and thank Everyone that contributed to this post because if it were not for all the helpful advice, My local Harley shop owner could of made payroll next month off of My bike!
That being said, I'll get to what was wrong. First of all, We all know you have to have 3 things all working together to make any internal combustion engine run!
(1) Proper Fuel and Air mix!
(2) Compression
(3) Ignition
Any one of these not properly functioning will result in an engine that won't start! So after going from the obvious, which in this case was the ignition because of the engine seeming to misfire, I checked, rechecked, and even checked that ignition again! After verifying that the ignition system was functioning properly and knowing that the engine had compression, it just made sense to look at the Fuel delivery system!
First I removed, cleaned, and checked the throttle body and all sensors related to that part of the motor!
Second, after I was very sure that the throttle body was in good order, I moved into the fuel tank. That is where the monster gave up its secret! The strainer on the bottom of the fuel pump assembly had completely disintegrated and there was pieces all over the bottom of the tank. After removing the fuel pump, I found that the pickup tube was clogged with what appeared to be a large amount of the screen material clogging the opening therefore preventing proper fuel flow but not completely keeping the engine from cranking and running. After seeing this, it all started to make sense because what I presumed was an ignition misfire, was actually the engine running lean which caused a higher than normal idle at low RPM and a leaning of the engine at a higher RPM thus causing the engine to start what appeared to be a misfire resulting in the ECM thinking that neither cylinder was firing properly and displaying a Non Combustion code for both cylinders!
Now everybody that heard this bike run and even the ones that were there when it started crapping out, all agreed that it was an ignition problem! Even the Harley Chief mechanic at My local shop stated that it was an ignition problem and worked on that basis while installing a new coil, spark plugs, Crankshaft sensor, and even disconnecting all connectors, cleaning, and reconnecting them, and yet the engine still had the same problem!
Frustrated, I went to this forum and the advice given resulted in My finding, identifying, and repairing this seemingly impossible to fix problem! The culprit all along was Ethynol fuel and its notorious ways of damaging fuel systems! Although I haven't been able to properly road test the bike due to the extreme cold weather here, I am 99% sure that what I found fixed the problem!
In conclusion, I will always check the fuel system first to make sure that Ethynol Monster hasn't crept back in and started eating away at the fuel lines and filters! After that I will always look elsewhere for the problem convinced that the fuel system is intact and working properly!
Thanks to All that contributed with their advice, and a special thanks to Chuck3049 for his insight and phone calls that greatly helped in determining the problem because if it not for all the suggestions from everyone here, I might of never found the problem and never been able to repair it my self saving me an untold amount of money that would have been spent at " The Stealer!"
Thanks Guys and I hope this post helps someone else having a similar problem like this!
Old Dec 29, 2012 | 07:28 PM
  #95
RANGER73's Avatar
RANGER73
Next round's on you.
Old Dec 29, 2012 | 07:35 PM
  #96
Cruzn34's Avatar
Cruzn34
" Belly up to the Bar Boys, I'm buying!"
Old Dec 29, 2012 | 07:36 PM
  #97
chuck3049's Avatar
chuck3049
Now go out and ride the heck out of it. glad you found it.
Old Dec 29, 2012 | 07:39 PM
  #98
Cruzn34's Avatar
Cruzn34
Thanks Chuck and I hope your headache got better!
Old Dec 29, 2012 | 07:41 PM
  #99
chuck3049's Avatar
chuck3049
Yup, just got that Jims 135 up and running. Wow what an awesome sound it makes. Can't wait to take it out for a ride. Should have seen the customes smile when we had him be the first to push the start button.
Old Dec 29, 2012 | 09:35 PM
  #100
QC's Avatar
QC
Awesome. Thanks for letting us know what it was. What was that said in post #8??
