Tools
Old Jan 11, 2013 | 07:33 AM
Sharkman73's Avatar
Sharkman73
I am a big fan of Craftsman like I stated above, but as others have said if there's one thing to not cut corners on it's your torx & hex bits....these are the most easily damaged and can cause some major headaches.
I have some off brand ones and some expensive ones, and there's a huge difference. Buy the best you can buy when it comes to torx & hex bits. Everything else you can get buy with less expensive or medium quality, but honestly I would recommend buying Snap-On torx & hex bits.
Old Jan 11, 2013 | 08:08 AM
zimm's Avatar
zimm
For starting out- Craftsman. No question the best for the money spent. Don't get their lower brand stuff, has to say "craftsman" for the no B.S. lifetime warranty. I really like to buy their small sets so you can carry the little plastic socket set to your bike and work on it from there. Snap-on, etc are top of the line and cost 10x the amount- perfect for professionals who can't afford the time to break a tool and go to sears. If you break a snap-on the truck comes to you with a new tool. It's important to know that snap-on and other tool trucks (Matco, etc) don't discount a single penny if you buy a set, so just the few tools that you use all the time. After you wrench for a while, pick a few select items you use all the time, and upgrade those to snap on. I started with a $18 snap-on phillips screwdriver, love it. For torq and allen sockets, I recommend SK. They are made in the USA, but price falls between craftsman and snap-on- found on ebay.
What I recommend to start out:
1/4" standard and 1/4" metric socket sets
3/8" standard and 3/8" metric socket sets
screwdriver set
combo wrench set in standard and metric
pliers set (slip joint, side cutters, channel locks)
torq socket set
standard and metric allen socket sets
1/4" and 3/8" drive universal joints if the sets didn't have them
3/8" drive torque wrench (click type) from craftsman
That should get you started for a few hundred dollars.
Old Jan 11, 2013 | 08:30 AM
skip3406's Avatar
skip3406
Most socket sets these days are 6 point so you need to get a few 12 point sockets for the working on brakes. 1/4, 3/8 & 10mm
Old Jan 11, 2013 | 10:58 AM
ynots's Avatar
ynots
Originally Posted by soft 02
If you dont wrench for a livin go cheep.
Good idea... that way when you damage the head of a bolt or fastener because of some low quality cheap *** tool you will have learned an important lesson. I wouldnt buy anything lower quality than a craftsman... been there done that
Old Jan 13, 2013 | 10:57 AM
hell hound's Avatar
hell hound
i have had mostly craftsman tools and they hold up great
Old Jan 13, 2013 | 12:41 PM
dirtdobber's Avatar
dirtdobber
I have always been a fan of Craftsman tools.
I have found that I have been paying too much for the same quality.
Home depot carries good tools and you will save a bunch doing it. yes, life time warranty just like craftsman.
The last several ratchets I have gotten from sears had problems and had to take them back. I still get their wrenches when I need one.
The kit I am speaking of from home depot is 220 piece with case. You can catch them on sale for $89.95, has a lot more tools than the sears kit that is run on sale for $99.95
Could be more tools than sears can't remember for sure. I have had more for 3 years now.
Then you could add more when ya need em.
Check with Amazon for tools. They have good prices at times.
just a thought
dd
Old Jan 13, 2013 | 02:19 PM
Junkster's Avatar
Junkster
I have been getting tools for xmas since I was 16. My Pops was a wrench. I am 50 now so todays Craftsman isnt like it used to be. They are still good tools, that are warrantied for life. What you need depends on how extensive you want to get into repairing your bike. General maintenance equals smaller tool kit. I have Craftsman, Snap-On, Matco, Lisle Specialty Tools and S&K tools. All are great tools, so it comes down to preference and price. I like click type torque wrenches. You will need larger tools if you get into tire removal, comp sprockets etc.
-Grumpy-
General Topics/Tech Tips
21
Mar 18, 2025 08:00 AM
Slimster1200
Aug 26, 2014 07:38 PM
HotIceHD
Jun 17, 2012 04:49 PM
spiritwarrior
Jan 19, 2009 10:11 AM
wwb
Nov 22, 2008 01:20 PM
