Noob exhaust question
Old Jan 29, 2013 | 11:14 AM
cagarcia03's Avatar
cagarcia03
Default Noob exhaust question
I've been doing some reaserch on here and I can't find anything on it.
I figured I'd ask you fine Gentlemen and/or ladies...
I just put on my V&H Dyna Outlaw 2-1 Exhaust and this thing is running HOT AZ HECK!! LIke burning my legs hot...it gets to the point that I have to turn off my bike at stop lights because of the heat...
Is anyone else who has this exhaust having the same issue??
If I wrap the Exhaust will it help or make it worse??
I love the Sound and performance gains...but this is ridiculous...
Is this normal or am I just being a pansy
Any info would be Greatly Appreciated...btw...My Stock Exhaust was not this hot...Does it matter that I put the O2 sensors?
Old Jan 29, 2013 | 12:21 PM
DYNAM1C's Avatar
DYNAM1C
Is ur bike tuned for ur exhaust? If ur running lean then that could be a reason if im not mistaken...
And does ur exhaust have any kind of coating whatsoever? I know the big radius from V&H comes with ceramic coating... If it doesnt then some heat shields or exhaust wrap would bring the heat down...
Old Jan 29, 2013 | 12:41 PM
cagarcia03's Avatar
cagarcia03
no. it's not tuned yet. and I think they are ceramic coated...I plan on wrapping them soon, but there really isn't a heat shield for them...thanks for the reply.
Old Jan 29, 2013 | 12:49 PM
matto371's Avatar
matto371
Any pipe with out heat shields will get super hot. Tunning it will help needs to run richer. Wrapping will help my supertrapp is wrapped and its not bad
Old Jan 29, 2013 | 01:01 PM
mattVA's Avatar
mattVA
Same exhaust. It gets hot. I've read wrapping the header actually makes the exhaust run hotter. Tuning might help but yes this exhaust is hot as it doesn't have a heat shield. I don't notice it on mine anymore as much because I don't find myself in 80+ degrees at stop lights very often.
Old Jan 29, 2013 | 02:22 PM
cagarcia03's Avatar
cagarcia03
And 80 Degree is all we get down here!!! LMAO! I've heard both that wrapping it makes run hotter and that wrapping may reduce some heat...maybe a wrap and some sort of spray...I need to get this fixed...it's really bad!
Old Jan 29, 2013 | 02:29 PM
DJY's Avatar
DJY
i would think that wrapping would keep exhaust hotter in the pipe and maybe a little cooler to the touch on outside of pipe.
Old Jan 29, 2013 | 03:30 PM
NSCoyote's Avatar
NSCoyote
wrapping the pipes will make the outside of the ehader cooler, but the ehat gets trapped in the pipe and alters the metalurgical properties of the steel in the pipe often tiems makign it weaker and more prone to cracking and breaking. start wit ha proper tune for the pipe to richen the AFR then if its still hot find someone aroudn with a good mandrel pipe bender *exhaust shop* and make some decent heat shields for it. if that doesnt work then look at wrapping it. given they are ceramic coated that with a tune might make it more bareable for you though
Old Jan 29, 2013 | 05:52 PM
DYNAM1C's Avatar
DYNAM1C
If it is ceramic coated then a tune is all you should need i think...
bmna2004
Dyna Parts
Mar 29, 2018 06:16 PM
jcsurf
EVO
Aug 19, 2017 07:37 PM
xtratoy
May 24, 2014 08:05 AM
SG Scott
Nov 5, 2009 10:04 PM
HDF Tech
Engine Mechanical Topics
Mar 18, 2006 09:58 AM
