Installing Lindbar on 2012 Switchback
Old Jan 31, 2013 | 07:29 AM
surfrat2's Avatar
surfrat2
Default Installing Lindbar on 2012 Switchback
I am attempting to install my Lindbars myself since it seems like an easy three bolt install. After opening the box and looking at the instructions I have a few questions. Do I remove the floorboards completely including the brake levers and clutch shifter in order to install? The instructions only say to loosen the bolts. Also, which loctite should I use, red or blue? Thanks for any help
Old Jan 31, 2013 | 11:43 AM
nevil's Avatar
nevil
Don't know for sure, but I would start just by loosening the bolts. If you don't have to remove stuff you saved time. Use blue loctite.
Old Feb 2, 2013 | 07:10 AM
surfrat2's Avatar
surfrat2
thanks for the info....the floorboards def will have to come off to install the bars, I guess they tell u to loosen them so that you have support for the brake at all times instead of just removing both brackets completley and having the weight of the boards pulling on the master cylinder. A problem I ran into tho is the Torx bolts thatt Harley seems to have welded on! I tried removing them but I'm not sure if I have the right size....Kuryakn mentions a T45 but there is some play in it, and since they are tight there is a real chance of stripping them. Anyone have any idea if they are T45 size?
Old Feb 2, 2013 | 10:41 AM
1HD1C's Avatar
1HD1C
from what i have read YES you have to remove them all the way and be careful, the white locktight that HD uses seems like it welds it to the bike so so best bet is to carefully heat the bolts with a torch to loosen the locktight..
a member of the switchback site ended up having his round out and he had to take the bike to the dealer to have it installed.
Old Feb 3, 2013 | 12:26 PM
surfrat2's Avatar
surfrat2
thanks again, I took my time and carefully broke the bolts free....now I'm considering replacing each one with a stainless hex head which might not be prone to slipping
Old Feb 3, 2013 | 12:38 PM
dirtdobber's Avatar
dirtdobber
If you do use stainless bolts make sure you use anti seize.
Stainless sometimes does not play well with others.
dd
norcal
Air Suspensions
16
Aug 22, 2012 09:06 PM
Ventana
General Topics/Tech Tips
14
Jul 10, 2012 08:07 PM
Rabid
Aug 10, 2009 07:34 PM
HD Renegade
May 21, 2009 12:37 AM
bowenammg
May 14, 2008 10:55 PM
