DAMN so close
Old Apr 27, 2013 | 10:48 AM
flyin1200's Avatar
flyin1200
You're not going to get 100whp with 255 cams. In fact I would be very happy at 88hp with this cams in a 103"
Old Apr 28, 2013 | 07:49 PM
ilovemyskidoo's Avatar
ilovemyskidoo
Originally Posted by JRK5892
even with big shots though that is plenty of pipe to let the motor scavange, a 2-1 pipe is not going to make that insane of a difference. if I was you I would look into a new tuner personally. or look up like builds dyno sheets and see what type of numbers they are pulling. yes they arejust numbers... but also, it is not cheap to do what you did, and you want to get the most out of it.
i've always had good luck with this dealer been doing business with them for many years. They did how ever just get the dyno machine just a couple years ago maybe their tuner is still new to this, how many hp's should I be getting? Again I have no complaints about My numbers and the bike has pleanty of power for Me now. But You are rite this hole project was not cheap at all, and if theres power left to pull out of this set up I want it.
Old Apr 28, 2013 | 09:30 PM
SLV's Avatar
SLV
I just googled "103 255 dyno sheet" and got a lot of results. It seems your numbers are right in the range for a stock compression 103 with stage 2 255.
PFWiz
Apr 22, 2014 03:13 PM
glide2meetu
Mar 11, 2011 02:01 PM
mhud
Mar 15, 2009 09:54 PM
rambobob
Feb 6, 2009 09:24 PM
jackinthebox
Dec 13, 2008 10:20 PM
