Need another horn!
Old May 6, 2013 | 07:25 PM
Austin Dave's Avatar
Austin Dave
There's no need to do away with the cowbell. Leave it where it is and mount a new horn anywhere you have a mind to.
Old May 7, 2013 | 06:37 PM
Dynam1te's Avatar
Dynam1te
Ok, I made a quick video just to show the Wolo model 619 for those interested. It isn't going to fit under the cowbell, and unless you want to fabricate a better place for it, I just replaced my factory horn with this one. Heres a good pic of what it looks like installed.
And here is the vid.
Old May 7, 2013 | 06:41 PM
shorelasHD's Avatar
shorelasHD
I put a set of Rivcos on my FXDF about 10 days before Hurricane Sandy swallowed the bike. Absolutely awesome and attention getting, highly recommended. I'm planning to put a set on my FXDWG in the near future......
Old May 7, 2013 | 08:13 PM
hollowpoint's Avatar
hollowpoint
Somewhere on this world wide web there are details on seperating the compressor from a Walo or a Stebel air horn so the horn can be fitted under the cowbell.
Using the original horn button, the wire runs under the tank & seat to the compressor mounted near (behind?) the battery. A hose returns by a similar route back to the horn behind the cowbell.
Old May 7, 2013 | 10:33 PM
128auto's Avatar
128auto
Sound awesome! Is there a way to hide it behind the rear cylinder? It might look better.
Old May 7, 2013 | 10:44 PM
heritageblue2013's Avatar
heritageblue2013
Probably better to just yell, hey a$$ wipe!
Old May 7, 2013 | 10:47 PM
skinman13's Avatar
skinman13
Now this maybe worth looking into...Thanks!
Old May 7, 2013 | 10:49 PM
skinman13's Avatar
skinman13
Well, I did yell, but not that...it was more like "you f'kn moron!"
Old May 8, 2013 | 12:11 AM
Spanners39's Avatar
Spanners39
You can tune the stock horn to a certain degree....there is a little screw with a locknut that does this.
Did you know Ozzy Osbourne's first job was tuning car horns at British Leyland??
Other than that, head down to a local wreckers yard with a small 12v battery and some wires, test a few car horns out and buy second hand. That is what I did on my Triumph Bonneville 100 years ago.
Old May 8, 2013 | 07:00 AM
blueangel73's Avatar
blueangel73
I think this is what you are refering to.
https://www.hdforums.com/forum/touri...n-install.html
