12' Super Glide Custom Forward Controls?
Old May 10, 2013 | 02:14 AM
TylerBoehm's Avatar
TylerBoehm
Default 12' Super Glide Custom Forward Controls?
Does anyone know if there are a set of forwards you can purchase that do not require the removal of the primary?
Old May 10, 2013 | 04:22 AM
artpe54's Avatar
artpe54
I have the Kury on mine, didn't have to remove the primary. They come with a cap to cover the old shift spline.
Old May 10, 2013 | 06:17 AM
TylerBoehm's Avatar
TylerBoehm
Did/do you have to cut it and then cap it?
Old May 11, 2013 | 07:00 AM
99superglide's Avatar
99superglide
All you have to do is remove the stock shift lever, push the splined shifter shaft in flush with the primary cover and then wedge the inboard shaft arm behind the bolt that fastens the tranny to the engine. Mine has been like this since it was new. You can leave it like this which will allow you to easily switch back to mid controls if you ever wanted to. I also never installed the new shift lever that goes on the tranny either. Seems the only difference is a shorter shift throw.
Old May 11, 2013 | 07:29 PM
Tepidy's Avatar
Tepidy
my ocd kicked in when i did mine i replaced the inner and outer primary because i didnt want to see the plug.Ive since went with switchback floorboards as well
turbotom1052
Jan 16, 2016 08:13 PM
love2ride71
Jun 6, 2010 06:35 PM
tweakin
May 17, 2008 09:21 PM
OhioSkully
May 9, 2008 07:10 AM
mdog2222
Apr 10, 2007 02:00 AM
