hesitates and pops
Old Jun 13, 2013 | 07:24 PM
bdtaylor1979's Avatar
bdtaylor1979
Originally Posted by Dewey71
No tool for exhaust leaks. I keep looking for a vacuum leak and havent found any. Cleared the codes and took it up the street. Engine light came back on, but it was running strong. I don't know what the problem is. Going to put on the heavy breather and see what happens.
Is it the same codes coming back or different ones?
Old Jun 15, 2013 | 11:11 AM
Dewey71's Avatar
Dewey71
It was the same codes. I finally solved the problem. The vacuum line had split on both ends. Earlier I was able to find and fix the front split,but wasn't able to see the one attached to the adapter that sits in between the jugs on top of the throttle body. Took the hypercharger off, yanked the little adapter off that makes the butterflys work. Basically I just have the hypercharger on my bike without the vacuum lines hooked up. Runs great, no engine light!! Just waiting on my se heavy breather to come in. Thanks everyone!
Old Jun 16, 2013 | 12:05 PM
bdtaylor1979
That's good, glad you got it figured out.
nomoore77
Mar 29, 2013 10:31 AM
Motosportman
Aug 25, 2008 07:02 PM
VenturaChop
May 27, 2007 01:09 PM
sportygm57
Apr 26, 2007 01:01 AM
mbmike
Exhaust System Topics
May 20, 2006 03:16 AM
