turns over slow but wont start
Old Jun 8, 2013 | 11:42 AM
Vanstreetbob's Avatar
Vanstreetbob
Default turns over slow but wont start
Well, a week into owning my 07 street bob it's let me down for the first, and im sure not the last time. I had been riding it all week with the nice weather here, came home last night with no problems. had a big weekend trip planned with some friends and of course come out this morning and the bike wouldnt start. turned over very slowly like it had a bad battery. I had my battey checked and its good, so from what ive been reading here, I need a new starter solenoid. too frustrated to deal with it now but we'll see if that fixes it next week
Old Jun 8, 2013 | 11:57 AM
02fx4dude's Avatar
02fx4dude
If it turns it's unlikely to be the solenoid. If the battery is good that narrows it to connections or the starter motor being bad.
Old Jun 8, 2013 | 12:01 PM
PennShovel's Avatar
PennShovel
Double check the battery to make sure the connections are good and tight. What is your battery reading?
Old Jun 8, 2013 | 12:02 PM
rooti's Avatar
rooti
did they do a battery load test?
Old Jun 8, 2013 | 12:23 PM
Vanstreetbob
battery was reading 12.69 volts and 285/300
Old Jun 8, 2013 | 12:26 PM
Vanstreetbob
I also had jumper cables on it from my truck a d it was doing the same so im assuming starter us going bad
Old Jun 8, 2013 | 12:28 PM
Dynam1te's Avatar
Dynam1te
Its most likely the starter. If it was the solenoid, it would just click. You can just un bolt the started and take it to get load tested, and when it proves bad, throw a new one in there. Starters go bad, its a part that needs replacing no biggie man, I'm sure you'll get lots of good miles outta your bob.
Old Jun 8, 2013 | 12:29 PM
Vanstreetbob
ya. ill give that a try.
Dynam1te's Avatar
Dynam1te
Not a good idea to try that on a bike.... They aren't meant to be jumped like car batteries are. If you 'have' to dont have the car running as you can mess up the coils, or damage the voltage regulator. I've heard a lot of horror storys of other **** gettin messed up when people try and jump their bike...
Old Jun 8, 2013 | 12:43 PM
tlb's Avatar
tlb
I wound remove and clean the ground to frame. Lots of people will check where the cable connects to the battery, but will not check the other end of the cables.
The ground getting dirty or corroded is fairly common, cause the problem you are having.
