OK it was bothering me not checking.... here is what I did....
Squeezed hose... it was tough to squeeze but it flexed a bit.... I cleared the codes the p0261/3 then turned off the ignition and waited a few minutes and turned the key again and just let it prime with No codes... after about 5 or 6 seconds after the pump turned off the codes came back without even trying to start the bike.
Any idea how to get the injectors out? I want to pull them and check the nozzles
You're thinking that you lost both injectors simultaneously? Not likely. I'd keep looking for the electrical problem. Something isn't telling them to fire.
F*uck yeah went out this morning reset my plugs pulled the fuses used an allen key to open the gas line pressure connector and then triple double quad checked everything and boom!!!!! Fired right up thanks guys happy fathers day
