JRI shocks on FXD
It took me the better part of a week to install them. Other time issues kept me from working on it steady but it’s a pretty simple job. I had to arrange for a helper for the measuring process, which was another scheduling delay. The timing issue was why I installed the shocks without calling Howard to guide me through the process. The big caliper from Harbor Freight made measuring the sag pretty easy.
I jacked up the bike, off with the old shocks on with the new. I took a little time to get the spacers right to make sure the shocks were parallel. I have the HD detachable bags which replace the upper shock mount with a slightly wider mount, which meant more spacing on the bottom as well. My helper and I got measurements with the bike on the jack with the wheels off the ground (measurement A) and the measurement with the bike upright on the ground with me in gear and feet on the forward controls (measurement B). Howards site list the JRI “B” as having 3.71” stroke (94mm). I set the sag at 1/3 of that (31mm). To finish the initial setup I set the sweep valve in the middle (about 22 clicks in, I think I counted 45 total). The shocks make the back of the bike sit up a bit more when unloaded. I didn’t measure it before so I can only eyeball it.
The first test ride was down Colfax through downtown. Over some of the rougher patches I noticed bumps that really worked up the front end seemed to go away before the back wheel hit them. On slow speed curves (like the curves right before the Denver mint) the lack of bouncing makes the bike feel much more stable.
A hundred or so miles, up Squaw Pass, Central City Parkway, and down 119 to Nederland showed the same improvements. The front end’s deficiencies show up even more on higher speed corners. In spots where I might have touched down the pegs before it seems like I wasn’t. The tires were put on a few weeks before and hadn’t been fully scrubbed in. After the ride the front was scrubbed up almost to the edge without much peg scrapping. I swapped out the old factory spec Dunlop’s for Metzler ME 880’s so the profile may be different to but I think I have a little more clearance with the slightly longer shocks.
Since then I’ve got about 1600 miles on the shocks mostly on 2 long weekend rides. The first was up I70 to Vail, through Minturn, Leadville, Keystone, (twice) and down through Buena Vista to Cripple Creek and back up through Woodland Park back to Denver. The second was down to Taos by 285 and around Northern MN for a day and back to Denver for the third day. I haven’t taken the bike for any long off road rides yet with the new shocks. I’m guessing it will be better in the dirt but the Dyna isn’t much of a dirt bike anyway (at least not with me riding it).
So what’s my take on the shocks? The only real downside is that they highlight just how bad the stock front end is. I seemed to notice it the most on higher speed turns, especially when the road was rougher. I have a set of the Gold valves from Racetech ready to go in to help the front end. I guess you could say the price is a downside too but for the improvement in ride and handling they’re worth a fair deal more than Howard charges for them. They are definitely plush for upright riding. They eliminate most (and soften the rest) of bumps in the road. They also give a big boost in confidence when putting the bike into turns. The combination of good valving for damping control coupled with springs that hold my ponderous bulk at the right ride height is really great.
I’m real happy with Howard’s recommendations’, surprised by the quick turnaround, pleased with the value for my money, and totally happy with the ride and performance. Why Harley doesn’t offer a decent suspension at least as an option on the big twins I don’t know (a test ride on the XR1200 proved to me that they can do a good suspension on a Sporty). For those that want a better than factory ride Motorcyclemetal and Howard are the way to go.
Maybe this should be a new thread but I've had a few Dyna wobbles before (usually in long high speed curves) and I've wondered if the True-Track does a good job of controlling them. The wobble comes from the front end and frame being rubber mounted to the engine/tranny and the swingarm? After the front end rebuild with the cartridge emulators I was hoping to tackle the frame issues next.
Would a fork brace be another must have for a decent suspension?
