Wheel alignment measurement and strap slack question 2010 fxdwg
Now on my bike the front nut as what I assume is a cap and the primary goes a bit in the way but on the swing arm theyre is a hole about 3.5 inch of the axle, my question being what is the right way of taking measurement, as I just made an Indy put a new tire I fear theyve done it wrong, if i take the hole until the axle i have a bit more than .5 inches difference. As if i take the front swingarm nut it is acceptable. While checking that I noticed a little play in the Wheel left side so I think a bearing is done but with 18000km ? really ?
Then for the belt tension (i know harley use a special tool that i dont have) on the plastic belt guard Under the bike theyre is a gauge what is the proper tension ? Mine is about near the top of it when i push on it (moves 3 quarter of an inch) feels too loose from my feeling but its not skipping any tooths and looks flawless.
Thanks for youre time
To measure from the little holes on the swingarm you need to be able to find the dead center of each hole on the axle. I did that by getting some little metal plugs with holes in the center that slip into the axle. Again if you put the adjusters back where they were, and your wheel was initially aligned, this doesn't change much.
Rear Tire Alignment uses the indentions on the swing arm measured to the center of the axle.
Belt tension measures "force against flex". I think the "force" measurement is about 10 lbs/ft. And the flex is like 5/8"???
HD-35381-A H-D BELT TENSION GAUGE
Check rear belt deflection:
As part of the pre-ride inspection.
At every scheduled service interval.
When checking belt deflection:
Set belt tension at tightest point in belt.
Measure belt deflection with motorcycle cold and the
approximate weight of the owner on motorcycle.
1. See Figure 1-25. Obtain H-D BELT TENSION
GAUGE (Part No. HD-35381-A).
NOTE
Customers may purchase gauge from an authorized Harley-
Davidson dealer.
2. To use the belt tension gauge:
a. Slide O-ring (4) toward 0 lbs (0 kg) mark (3).
b. Fit belt cradle (2) against bottom of drive belt half-way
between drive pulleys (point 3 in Figure 1-26.)
c. Press upward on **** (6) until O-ring slides down to
10 lbs (4.5 kg) mark (5).
d. See Figure 1-27. Measure belt deflection as viewed
through deflection viewing window (2) while holding
gauge steady. Deflection graduations (3) are 1/8
in. (3.2 mm) apart.
3. See Figure 1-26. Check drive belt deflection. Apply 10
lbs (4.5 kg) of force upward at point 3.
4. Measure belt deflection several times, each time with belt
moved (by rotating rear wheel) to a different position on
sprockets.
5. Refer to Table 1-11. Compare drive belt deflection with
specifications listed in the table.
NOTE
Do not rely on "feel" for the proper deflection as this typically
results in belts which are under tensioned. Always use H-D
BELT TENSION GAUGE (Part No. HD-35381-A) to determine
the 10 lb. (4.5 kg) deflection force. Loose belts will fail due to
"ratcheting" (jumping a tooth) with resultant tensile cord
crimping and breakage.
Table 1-11. Rear Belt Deflection
FXDWG/FXD/FXDF FXDB/FXDC/FXDL
IN. MM IN. MM
With motorcycle on 5/16-3/8 7.9-9.5 1/4-5/16 6.4-7.9
jiffy stand without
rider or luggage
Vehicle upright with 1/2-9/16 12.7-14.3 5/16-3/8 7.9-9.5
rear wheel in air
If belt adjustment is necessary, perform the following procedure:
1. See Figure 1-28. Remove retaining ring (3) and loosen
axle nut (2).
2. Adjust belt tension by turning the axle adjusters (1) an
equal number of turns to keep the wheel aligned until the
specification in Table 1-11 is achieved.
3. Tighten axle nut (2) to 95-105 ft-lbs (128.8-142.4 Nm).
4. Install retaining ring (3).
5. Tighten adjuster screws to 96-120 in-lbs (10.8-13.6 Nm).
6. Verify rear wheel alignment. See 2.11 VEHICLE ALIGNMENT.
Check wheel bearing end play after tightening axle nut to
specified torque. Excessive end play can adversely affect
stability and handling. Insufficient end play can cause
bearing seizure. Either condition can cause loss of control,
which could result in death or serious injury. (00285a)
7. Check wheel bearing end play. See 2.5 SEALED WHEEL
BEARINGS, Inspection
Only a Harley-Davidson dealer should perform vehicle
alignment. Improper alignment can adversely affect stability
and handling, which could result in death or serious
injury. (00060a)
Check vehicle alignment according to following procedures.
Incorrect alignment can adversely affect stability and
handling, which could result in death or serious injury.
(00287a)
1. Verify wheels are true to specifications. See 2.9 TRUING
LACED WHEELS or 2.10 CHECKING CAST WHEEL
RUNOUT
2. Check steering head bearing adjustment and adjust if
necessary. See 2.18 STEERING HEAD.
3. See Figure 2-59. To ensure accurate measurements,
obtain a piece of 1/8 in. (3.2 mm) aluminum welding rod
12.25 in. (311 mm) long. Grind one end down to a blunt
point. With a pliers, bend the rod 90° as shown. Place a
snug fitting O-ring or cable strap on the rod to act as a
slide measurement indicator.
4. Obtain AXLE ALIGNMENT PLUG SET (Part No. HD-
48856). See Figure 2-57. Insert axle alignment plugs (1,
2) into left and right ends of rear axle.
5. See Figure 2-58. With the blunt point of the alignment tool
inserted in the rear fork pilot hole, slide the O-ring along
the tool until it is aligned with the center of the alignment
plug as shown. Measure and record distance from end of
tool to O-ring. Repeat for the other side of the motorcycle.
sm03937
1. Alignment plug (left side)
2. Alignment plug (right side)
3. Alignment hole
Figure 2-57. Axle Alignment Plugs
sm03771
Figure 2-58. Measuring Alignment
sm02240
1. O-ring
2. 1.25 in (32 mm)
3. 10.0 in (254 mm)
Figure 2-59. Alignment Tool
6. See Figure 2-60. The measurement between the center
of the rear axle and the rear fork hole must be equal to
within 1/32 in. (0.8 mm) on both sides of the motorcycle.
If it is not, adjust the rear wheel with the axle adjusters to
accomplish the equal measurement. It is extremely
important that this adjustment be made as accurately as
possible in order to make the remaining adjustments
accurate.
7. Raise the rear of the motorcycle so that the rear wheel
spins freely. Do this by placing a center stand or blocking
under the frame.
8. See Figure 2-61. Remove the bolt (2) which attaches the
top stabilizer link (1) to the engine mounting bracket.
9. Position front wheel so brake disc is vertical using an
inclinometer. If possible, use a digital inclinometer for the
best accuracy.
2-30
The exhaust system must be in place while performing
the following steps.
Motorcycle must be upright and level before performing
this procedure.
Stabilizer link should only be loosened/adjusted on end
with threads showing. Adjusting or loosening other end
will tear the isolator.
There should be 0.25 in. (6.4 mm) minimum clearance
between the fuel tank tunnel and the head of the left stabilizer
link mounting bolt.
10. Loosen jam nut (3) on stabilizer link. Adjust the stabilizer
so that the bolt removed in previous step can be reinstalled
without pushing the engine to the right or left. Tighten jam
nut.
11. Check the rear brake disc with the inclinometer to ensure
that it is parallel to the front brake disc.
12. If the rear brake disc is not parallel to the front brake disc,
adjust the top stabilizer link until the rear brake is parallel
to within 1 degree of the front brake disc's position.
13. If you cannot adjust the front and rear brake discs to within
1°, inspect the frame, front fork and/or rear fork for
damage.
To prevent damage to fuel tank and possible fire or
explosion, which could cause death or serious injury,
maintain clearance specified in service manual between
fuel tank and head of left stabilizing link mounting bolt.
(00262a)
14. If you have to adjust the top stabilizer link more than five
full turns to bring the brake discs to specification, again
inspect the frame, front fork and/or rear fork for damage.
15. Tighten the stabilizer jam nut (3).
NOTE
If the stabilizer link has been adjusted more than five full turns,
the vehicle's vibration will very likely have reached an unacceptable
level. Adjust the vehicle's vibration level as follows:
16. Be sure the transmission is in neutral.
17. Loosen, but do not remove, ALL the mounting bolts on
the engine isolators and start the engine. Let the engine
run for approximately 5 seconds. This will center the
mounts on the frame and power train assembly.
18. Tighten isolator mounting bolts to 25 ft-lbs (33.9 Nm).
sm02469
1. Top stabilizer link
2. Bolt
3. Jam nut
4. Adjusting stud (nut)
Figure 2-61.Top Stabilizer
Just an FYI on the belt tension. The HD Service tech told me that he fist does a hand check on belt tightness. And he only gets out the guage if he suspects a problem. He said that the force required to flex the belt ( when sufficiently tight ) should increase exponentially after exceeding the maximum flex rating. So you should be able to flex the belt by hand to the setpoint. But it should take an extreame amount of force to go beyond that.
