Put mini apes on my FXDC, slight rattle now.
Old Sep 12, 2013 | 04:29 AM
TylerBoehm's Avatar
TylerBoehm
Default Put mini apes on my FXDC, slight rattle now.
Went to 12" mini apes and had dealer do it. Now I get a rattle/bad vibration at about 2800-3000 rpm. Is this common?
Old Sep 12, 2013 | 07:28 AM
spyderwebb's Avatar
spyderwebb
No, something is loose, you are going to have to track it down and secure it...better yet the dealer needs to track it down and secure what ever is loose.... and being as it's the handlebars and their job, I would make it their priority!
Old Sep 12, 2013 | 08:29 AM
Jr Bob Dobbs's Avatar
Jr Bob Dobbs
Default Wired rattle
I went to 10" mini apes now at high rpms I here a rattle but the rattle stops as soon as I shift into another gear. The rattle seems to be coming from under the bike. Would it be possible that the kick stand is vibrating causing the rattle? Maybe the spring has sprung a bit?
Old Sep 12, 2013 | 05:37 PM
99%r's Avatar
99%r
Recheck there work- Recheck all bolts to make sure they are tight.
Is the vibration just in the handle bars? If so put the poly bushings in. JP cycles has them for $10
Old Sep 12, 2013 | 07:06 PM
Mascman's Avatar
Mascman
Just a thought...is it the clutch lever?
Maybe the adjustment is a little looser than what you had before changing the bars out. easy enough to check it out.
Mine rattles a bit...been thinking of making a washer from milk jug to put in there to dampen the noise.
Old Sep 12, 2013 | 09:37 PM
TylerBoehm's Avatar
TylerBoehm
I will have to check, I appreciate the input. It does sound like its something loose rattling around, I've tried pushing down on a few things while riding to see of it stops but its a little tricky to do. It is not the clutch lever because if I put a finger on it it will still do it. Maybe a mirror or something
Old Sep 13, 2013 | 05:51 AM
blueangel73's Avatar
blueangel73
My clutch lever rattles when I remove my hand from the bar. It has done this with every set of apes I have had. the vibration from the bike is magnified across the rise in the bars and without my hand up there to obsorb the vibration the rattle can get annoying. Other than that, I don't know what to tell you, just have the dealer look it over and fix your issue if posisble.
Old Sep 13, 2013 | 11:15 PM
TylerBoehm's Avatar
TylerBoehm
Had a guy at the dealer ride it and it ended up being the fuel cap. Wasn't sealing all of the way. He threw a new one on there for free. +1 on awesome service and good people.
TUCCI
Aug 12, 2018 04:43 PM
hondo1
Feb 4, 2011 12:24 PM
frankiefire702
Nov 16, 2009 07:53 PM
Crowdog
Oct 2, 2009 02:12 PM
Dragon919!
Jul 29, 2007 09:43 PM
