Pending Issue???
Old Oct 8, 2013 | 08:33 PM
WideGlideFever's Avatar
WideGlideFever
Ok, so after I serviced my ride last weekend, I was still having the starting issue. Then I remembered reading something on here a while ago and decided to give this a try before replacing the neutral safety swtich.
Replaced the batteries in the FOB. Problem sovled. My bike is a 2011. So probably built sometime in 2010. I didnt actually take delivery till Jan 2012. This being 2013, those batteries are probably a few years old, so I replaced them both. The first time I went to start the bike after replacing the battery I had to push the start button 3 times before it kicked over. I am assuming the FOB had to synch up. Ever since then I have had no issues.
Hopefully this will help someone out in the future that runs across the same issue.
Old Oct 8, 2013 | 10:00 PM
Jack Russell's Avatar
Jack Russell
Default Intermittent starts
Originally Posted by WideGlideFever
Wondering if anyone has had this same issue/symptom and could tell me if its anything to worry about:
So yesterday when I went to get on the bike I turned the power on, hit run, fuel primed, and when I went to push start...Nothing. The bike was in neutral, but I thought maybe it wasn't "all the way" in neutral. So I turned the power off, downshifted and back up to neutral, repeated steps and started up no problem. Chalked it up as nothing to worry about.
This morning leaving for work, I usually coast out of the driveway onto the street a little bit before firing it up so I dont disturb my roomies. Well I was coasting down the road, so definitely in neutral and same thing happens, push start and Nothing. I shifted into 2nd and pop started.
One more time today leaving for work, same things happens again. Now this is three times in less than 24 hours, so I am starting to get concerned.
Anyone know what is around the corner for me?
Appreciate the input!
Check or replace the starter relay. 7.00$ at dealer. i have been here trust me and get a back up.
Old Oct 8, 2013 | 10:13 PM
WideGlideFever
Thanks for the tip, I will keep it in mind if it starts acting up again
badboyvky666
Nov 26, 2014 04:14 AM
TurkeyRun
Nov 12, 2012 09:44 AM
SICKBAGGER
Apr 26, 2012 09:31 AM
Pony Soldier
General Topics/Tech Tips
Sep 10, 2010 12:46 PM
jousley
Aug 28, 2009 09:50 PM
