2012 WG upgrades ?
Old Nov 6, 2013 | 11:05 AM
AllenW's Avatar
AllenW
Default 2012 WG upgrades ?
I have a 2012 WG with one inch over Progressive rear shocks and am looking at several things I want to do to it.
I'd like to add maybe 4" over tubes to get the front end up a bit and add 12" Builtwell apes, not sure what length cables or electrical extension I'll need. ??
Like to order whatever I need before I disassemble anything.
Also can you use any other riser with these bars, as I'm not to fond of "Builtwell" being stamped on the riser??
TIA
Al
Old Nov 6, 2013 | 12:06 PM
TX Rebel's Avatar
TX Rebel
There is plenty of wire in the handle bars for 12in apes, no extensions needed. Buy the handle bars and risers and do a mock up and measure for cables. Some have done 12in without longer cables. Any 1in bar risers will work.
Old Nov 6, 2013 | 01:05 PM
! rock103 !'s Avatar
! rock103 !
TIA
Al
Where do you plan on getting the +4" over fork tubes?
Old Nov 6, 2013 | 02:19 PM
AllenW's Avatar
AllenW
Hadn't really looked but if I can find the receipt years back I got longer tubes for my drag bike, somebodies got to make them..don't they??
Al
Old Nov 6, 2013 | 03:04 PM
! rock103 !
Trick is finding them in 49mm
Old Nov 6, 2013 | 07:59 PM
Panimal's Avatar
Panimal
Custom Cycle Engineering has the extended 49mm tubes...
http://www.ccesd.us/index.php?main_p...&cPath=128_189
You can get them up to 8"over, but that's it due to the 49mm tubes having a thinner wall thickness than the 41mm tubes. I'm in the process of cutting and stretching the frame on my 2012 Wide Glide, and I'll need longer than 8" over tubes, so I'm planning to sell my complete 49mm front end, and go to a 41mm custom set of trees and the tubes I'll need.
Old Nov 6, 2013 | 08:33 PM
AllenW's Avatar
AllenW
Thanks, I had thought of going with a 4 to 6 over narrower and smaller tubed front end, but kept hearing horror stories of poor handling, not sure why though.
Al
Old Nov 7, 2013 | 10:26 AM
Reindeer's Avatar
Reindeer
You going to add more rake or just put longer tubes in?
Old Nov 7, 2013 | 10:52 AM
! rock103 !
Nice link! Thanks for the info...
Old Nov 7, 2013 | 11:00 AM
AllenW's Avatar
AllenW
Original thought was 6 over with enough rake to get bike level again with the smaller diameter tubes.
The 4" over tube probably not, I figure it'll take about 2+" to get bike back to where it was and another inch or two to play with.
Trying to talk the neighbor into selling me his bike and just make a retro chopper out of it, and then I'd prob just do minor stuff to the WG
Al
