loose mufflers
Old Dec 12, 2013 | 02:26 AM
hobo1's Avatar
hobo1
Default loose mufflers
I switched stock 2 into 1 exhaust for a stock head double pipe on my 12 FLD.
I also put screaming eagle mufflers on.
Only trouble is the mufflers don't clamp tight to the head pipes and I blew them off the damn bike a while back.
I put them back on and tightened the hell out of the claps n now here a few months later the mufflers are loose as **** again!
Any suggestions for a fix over the winter here to correct my issue?
Old Dec 12, 2013 | 04:11 AM
stilup's Avatar
stilup
You need to adapt some braces to secure it better.
My stock exhaust had three clmaping areas .
Utilizing some stock braces.
I'm saving all my stock irems but you can find them on Ebay for a song.
Old Dec 12, 2013 | 04:33 AM
hobo1's Avatar
hobo1
Ok put that in laymans (I'm a idiot n didn't quite catch your drift) terms. Lol
Old Dec 12, 2013 | 09:07 AM
sixguns's Avatar
sixguns
Head pipe clamps are not meant to be the only point of attachment, there should be a bracket that attaches to and secures the muffler, On your FLD the bracket attaches to the Transmission, then the muffler so the muffler can not slide back off the head pipe. Sounds like you are missing that bracket.
Old Dec 12, 2013 | 10:14 AM
hobo1's Avatar
hobo1
Right the factory setup had a muffler bracket for the SINGLE muffler that atached to the tranny!
Im working with a two into two pipe tho!
The header pipes are secure all the way back but there is nothing holding up the mufflers except the clamps.
Old Dec 12, 2013 | 10:20 AM
hobo1's Avatar
hobo1
I still have my factory parts. I'm debating gutting the cat n going back to the 2 into 1 set up again tho if I have no choice.
Old Dec 12, 2013 | 10:52 AM
DesertDyna's Avatar
DesertDyna
You need to fab up a bracket or go to the muffler manufacturer site to see what they have available. If your mufflers were made to replace OEM ones...they usually re-use a stock type bracket...or provide one.
Old Dec 12, 2013 | 02:35 PM
dirtdobber's Avatar
dirtdobber
I had the same problem. Make sure the mufflers are all the way up on the header. They go on the header farther than most mufflers do. Least wise mine does. It would not tighten either.
After I did that it solved my problem.
Old Dec 16, 2013 | 04:52 AM
hobo1's Avatar
hobo1
Talked to my local Harley Guru n I'm going to shim where the muff clamps on.
The clamp is bottoming out n not putting enuf pressure in the head pipe to secure it proper. Try that fix n see what happens.
Thanks yall for the advice n ill keep ya informed what's the turnout.
Old Dec 16, 2013 | 07:16 PM
mud's Avatar
mud
simply run a screw, or two, through each muffler into each pipe.
orin
Jul 22, 2017 01:55 PM
MiniWolf
Aug 17, 2012 07:12 AM
dondee
38
Aug 2, 2012 01:27 AM
odie-in-az
Jul 27, 2010 02:29 PM
dylanchua
Feb 26, 2009 09:38 AM
