Front Axle Cap
Old Dec 24, 2013 | 07:27 PM
grumpy56's Avatar
grumpy56
Default Front Axle Cap
Just put a new front tire on my 2006 Super Glide, and after reviewing some of the related threads here, the position of the axle cap is very confusing. When I pulled it off (had never been taken off from the day I bought it), the cast in spacer was at the front. The shop manual states that the cast in spacer is positioned towards the rear. Also, in the 2006 Dyna Manual, it states that the rear bolt is torqued first and the front last, unlike some newer models, that I gather from some other discussions here, are the opposite. I have a gap at the front now. Any guidance is appreciated before I bolt out on to a SoCal freeway. Thanks.
Old Dec 24, 2013 | 07:40 PM
ynots's Avatar
ynots
my 2010 manual was the same way, exactly opposite of the way it was mounted from the factory. I put it back on like it was (spacer in front) and torqued the spacer side first
Old Dec 24, 2013 | 07:41 PM
mud's Avatar
mud
go with the manual.
Old Dec 24, 2013 | 07:49 PM
ynots's Avatar
ynots
I dont think it even maters which location the spacer is in. I would just be sure and torque the spacer side first so the spacer contacts the lower leg and only leaves a gap on one side. tight is tight
Old Dec 25, 2013 | 09:25 AM
grumpy56's Avatar
grumpy56
Thanks. I assembled it per the manual and now there is just a gap at the front rather than the rear. Probably doesn't matter and even if it does loosen the axle won't fall out, but you would probably have some funky fork action going on.
Mkos1980
Jan 13, 2016 08:18 AM
Jake White
Apr 12, 2012 08:34 AM
mang0
Wheels/Tires
Sep 7, 2011 10:59 AM
2010fxdwgrider
Jun 26, 2011 06:24 AM
acoers
Mar 19, 2011 02:28 PM
