Easy Bracket Vs. Barebacks
Old Mar 7, 2014 | 10:09 AM
  #41
SLV's Avatar
SLV
OK, you can use them with the detachable hardware, you just leave out a spacer. It doesn't say the thread size though.
http://www.cyclevisions.com/index.ph...v127_cv145.pdf
I can say for sure that my original fender/TS fasteners were 5/16x24 and the Barebacks are 3/8x16. Their data doesn't seem to address this at all.
It's good to know that they work with detachable though.
Old Mar 7, 2014 | 10:43 AM
  #42
KEYBEAR's Avatar
KEYBEAR
I have the Barebacks and like them . I made the mistake of thinking the Bareback brackets needed to line up (position Both in the 12 o,clock ) It made it very hard to line up to install and remove . I found if I put the back bracket in the 12 o,clock position and the front bracket in the 2 o,clock position it was a lot easier . Now I release the back tip up and remove the front and does not need three hands to do .
Old Mar 7, 2014 | 08:51 PM
  #43
izzyryder's Avatar
izzyryder
I don't know if there is a difference in years, but my kit had 3/8x16 bolts and my fender bolts were 3/8 as well.
When putting the male cycle vision bolt in the rear i notice that it protrudes pretty far in the fender well. I'm concerned it's going to hit the tire. Does anyone else's do this?
Old Mar 7, 2014 | 09:29 PM
  #44
izzyryder's Avatar
izzyryder
Here's a pic of what I mean...
Attached Thumbnails Easy Bracket Vs. Barebacks-image-207379110.jpg   Easy Bracket Vs. Barebacks-image-2207943790.jpg
Old Mar 7, 2014 | 09:37 PM
  #45
8541hog's Avatar
8541hog
Since you are using T-nuts, cut the bolts flush with the T-nut.
Old Mar 7, 2014 | 09:45 PM
  #46
izzyryder's Avatar
izzyryder
yeah.. damn.. i hoping I wasn't gonna have to pull it and cut it.
Old Mar 7, 2014 | 09:59 PM
  #47
izzyryder's Avatar
izzyryder
Here's how the bags look with the cycle visions bare backs and without...
Old Mar 7, 2014 | 10:06 PM
  #48
SLV's Avatar
SLV
Sweet. They look good. Are you happy with the bags? I'm pretty impressed with their function for the price.
Old Mar 7, 2014 | 10:22 PM
  #49
izzyryder's Avatar
izzyryder
I am happy with the look.. but they are a bit small.. I got the large size and probably should have went with the XL's.
Greg Di
Jan 9, 2013 04:21 AM
Mal74
Jun 16, 2012 04:13 PM
rsofa
May 30, 2009 09:25 AM
frozensoul
Feb 23, 2009 01:13 PM
pic824
Dec 15, 2007 03:41 PM
