Quick servicing question
Old Jan 11, 2014 | 03:54 PM
suthpaw22's Avatar
suthpaw22
Default Quick servicing question
Changing my fluids for the first time today. I am using SYN3. I have drained all fluids and installed the new filter. How many quarts go in eng/trans/primary. Also, what is the primary torqued back to?
Old Jan 11, 2014 | 04:43 PM
99%r's Avatar
99%r
What year of bike you working on?
My 2011 Fxdc takes 2 1/2 quarts in the motor. I suggest putting in 2 1/2 and checking your level
1 quart in the tranny
1 quart in the primary.
I just tighten the derby cover I don't torque it. It has a rubber seal, doesn't need to be super tight
Old Jan 11, 2014 | 05:03 PM
bdtaylor1979's Avatar
bdtaylor1979
Old Jan 11, 2014 | 05:15 PM
suthpaw22's Avatar
suthpaw22
Its a 2014 Dyna Super Glide. I put 1 in the tranny, 1 in the primary, and about 2 7/8 in the eng. I warmed it up after 2 and added a little until it was right at full. Thanks for the feedback.
Old Jan 11, 2014 | 05:29 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
If you find you have too much engine oil on a hot engine you can use a turkey baster to suck some out. I typically leave about a 1/2 inch short on the dipstick and on a hot engine it works out fine. Doesn't your owner's manual have a drawing for oil quantity levels?
Old Jan 12, 2014 | 07:31 AM
suthpaw22's Avatar
suthpaw22
I forgot and left my manual in my desk at work I was flying a little in the dark, but its all good now.
Old Jan 12, 2014 | 07:37 AM
Iceman24's Avatar
Iceman24
Gonna see some flack on using Syn3 oil...
For the primary cover:
1. Replace torx w/SS bolts (better and won't strip inner-torx socket).
2. Tighten in star-pattern to ensure you get it on even.
3. Tighten to "feel" because snapped bolts suck.
Old Jan 12, 2014 | 09:19 AM
suthpaw22's Avatar
suthpaw22
Does someone sell the SS bolts as a set to replace these?
Old Jan 12, 2014 | 02:29 PM
nevil's Avatar
nevil
Yes. Ace Hardware, Boltdepo.com, Fastenal as well as others.
jimaw2
Oct 28, 2011 06:42 AM
clayharley
Apr 7, 2010 10:00 AM
Deluxechuck
Apr 7, 2008 08:59 PM
dawg
May 22, 2007 05:59 PM
vze4gqv6
Nov 28, 2006 02:42 PM
