Vibra-Technics motor mount install
Old Feb 10, 2017 | 12:41 PM
  #401
blueangel73's Avatar
blueangel73
The UK site was great info, ordered the part and it will be at my door two days later.
Old Feb 10, 2017 | 01:59 PM
  #402
F86's Avatar
F86
Awesome! Mine arrived very quickly as well. I highly recommend combining the install with an oil change... While I've done it without too much difficulty with the filter in place, it's really a breeze without it!
Old Feb 18, 2017 | 11:32 AM
  #403
misfitJason's Avatar
misfitJason
Anybody have issues with the motor hitting the frame when idling. I sometimes get it and it can be felt at idle and deceleration with the technics mount
Old Feb 18, 2017 | 02:33 PM
  #404
tomt's Avatar
tomt
Loosen the middle bolt. Have someone sit on the bike. Don't know if having the feet on the ground or not makes a difference. If after torqueing the bolt back to specs the engine still hits the frame. Use a third guy to hold the bike up and have the guy sitting on the bike take his feet off the ground.
Sitting on the bike brings the engine back a little. Torqueing the bolt keeps the engine back there, in place. Now, if the rear shock is bad this may cause the engine to move to far forward. You will need to replace it.
How do I know? I made the installation video for Vibra-Technics Website.
Old Feb 18, 2017 | 02:56 PM
  #405
Max Headflow's Avatar
Max Headflow
I thought that the issue was the rear bottom mount was hitting the frame on decel.. Wouldn't what you are doing cause the issue to be worse? Is it someplace up front where the motor is hitting the frame??
Old Feb 18, 2017 | 03:55 PM
  #406
tomt's Avatar
tomt
On mine the front exhaust heat shield was hitting the frame. Check and see if you have a little nick/dent in the paint, on the frame tube.
I was told by Phil Bentley from Vibra-Technics to do this fix. It worked. This fix isn't in the video because Vibra-Technics put the video on their site, before I took the bike for a test ride.
Hope this helps.
Old Feb 18, 2017 | 10:11 PM
  #407
Reindeer's Avatar
Reindeer
Just ordered the Predator mount. Been thinking about it for awhile. Figured since my motor is on it's way to Darkhorse that this would be a good time to replace it.
Old Feb 19, 2017 | 09:49 AM
  #408
misfitJason
Hope this helps.
Thanks for the tip. I am going to try this today but my front cylinder and pipe have a crap ton of room between them and the front frame rail. I just did an alignment at the top motor mount but didn't loosen the lower mounts and run the bike. I am going to try that. For the life of me I can't figure out where it's hitting at because everywhere looks like it has clearance. It can feel it in the pegs and something is definitely contacting in the rear or lower area.
I can't find any witness marks though yet
Old Feb 19, 2017 | 11:03 AM
  #409
Max Headflow
Hope this helps.
In your case was the vibes on decel or accel?
Old Feb 19, 2017 | 11:18 AM
  #410
tomt's Avatar
tomt
Rear mount might be shot. How many miles on it?
Before I changed the front mount (It only had 7200 miles on it) with a new OEM mount. The old mount was so bad, the engine was lying on the lower frame. I had no vibrations what so ever. When I first heard the banging sound with the old mount. I thought the steering neck/stem bearings wear loose. With more investigating, I found the front exhaust heat shield was hitting the frame when I hit bumps in the road. I put the new mount on and it stopped.
Phil e-mailed me. He saw my video on installing an OEM mount and asked me, if he sent me a Predator Mount would I make a installation video for him.
I installed the mount, took it for a ride and I got the engine exhaust shield hitting the frame again. I E-mailed him the problem and he gave me the fix I mentioned. Once again problem solved.
Your noise could be coming from anywhere. Check for misaligned or loose exhaust mounts at the front and rear. Check your shock mounts. You have to lift the rear off the ground, to check this. It doesn't hurt to check things that are not even related.
Hope this helps.
