TORX bits required?
Old Apr 22, 2016 | 09:03 AM
  #41
ChapmanMFG's Avatar
ChapmanMFG
Former Sponsor
Thanks for the info, we will have ESD safe conductive safe sets soon, I didn't know whether they were applicable to your work. We have a lot of customers in the high-tech defense industries who work in ESD safe clean rooms.
We are working on a universal joint now! We've made some prototypes and are running a small production run today. I'll have to get back to you on the torque range, but it will probably be around 200in lbs because that's the max torque for our ratchet. Here are so some photos on a prototype, it's not black oxided
Are you on our e-newsletter? When they are available (and other new stuff/deals) are available I send it out there first, usually about once a month. You can sign up on the top of our home page.
Old Apr 22, 2016 | 09:08 AM
  #42
cggorman's Avatar
cggorman
I'll check it out. Thanks.
Old Apr 22, 2016 | 10:47 AM
  #43
Reindeer's Avatar
Reindeer
Originally Posted by ChapmanMFG
Our 1903H Motorcycle set
Has Phillips, Slotted, SAE hex and star bits size T8 - T30 and does include the T27! This kit was designed in collaboration with Harley owners.
You can use the code HD Forum to save 15%
I've been looking for something like that to throw in a saddlebag. Thanks for the link/code.
Old Apr 22, 2016 | 10:57 AM
  #44
ChapmanMFG's Avatar
ChapmanMFG
Former Sponsor
You're welcome! I'm a horse guy, when the first customer called me and said "I'm looking for a screwdriver set to keep in my saddle bag," I thought to myself "why do you need a set of screwdrivers for a horse?" Luckily I kept my mouth shut and figured it out quickly, because he would have thought I was a complete idiot.
Let me know how you like the set!
Old Apr 22, 2016 | 03:14 PM
  #45
cggorman's Avatar
cggorman
Maybe an "extreme" system with a ratchet that will accept ultra short bits but not let them pass all the way thru. I made this and used a box end wrench modified with no angle to hold it but it was hard to get axial pressure on the bit since it passed right thru the wrench. It kept wanting to cam out of the bolt. I should have welded it to a bar but ended up just cutting off the bolt head with a sawz-all. Worked for since since I didn't plan to replace the bolt.
Old Apr 28, 2016 | 06:32 AM
  #46
ChapmanMFG's Avatar
ChapmanMFG
Former Sponsor
Thanks for the suggestion! We are looking into making very short bits without a knurl, so when you put them in our ratchet the drive end sticks out a little bit and the other end is flush with the ratchet gear.
I got a call a while ago from a customer who works in a specialty machine shop, and each guy on his team carries two Chapman sets, one regular one and the other with all the ends of the bits cut off for really tight spots.
We're also in the process of making longer bits for recessed screws.
Thanks again and keep in touch!
Old Jun 1, 2016 | 08:27 AM
  #47
ChapmanMFG's Avatar
ChapmanMFG
Former Sponsor
Someone on here asked me to keep you guys updated with new stuff, right now we have a short production run of 6" extensions on our website http://chapmanmfg.com/products/cme-1...nt=19461863491
Old Jun 1, 2016 | 09:15 AM
  #48
DianneB's Avatar
DianneB
I have smaller Torx but had to go out and buy a T-45 to do my forks.
dynafan68
Oct 19, 2009 03:01 PM
beary
Mar 14, 2009 07:44 PM
bakerm75
Feb 8, 2009 10:34 PM
RCNFVR
Jan 25, 2009 10:15 AM
MikeO
May 10, 2006 04:45 PM
