V&H clearance issue to frame FXDL
Old May 3, 2014 | 02:20 AM
John_K's Avatar
John_K
Unhappy V&H clearance issue to frame FXDL
Working on my recently acquired '00 Low Rider getting it ready for the road, fixing all the bugs and issues. I've come across a rub, the front header is touching the frame tube. Exhaust is V&H straight shot slipons, and there is no clearance to the frame. The heat shield is rubbing, and removing it only gives maybe 3/16" space. I've noticed looking at other's bikes in the threads some have up to 3/4" or more clearance, others are a little tighter, but mine is actually rubbing... that can't be good and I don't like it
What gives?? ? How can I fix this issue?
Old May 3, 2014 | 04:19 AM
br549A1's Avatar
br549A1
Check your front and rear motor mounts. Sounds like it sunk if that is the right pipe for the bike
Old May 3, 2014 | 04:32 AM
John_K's Avatar
John_K
I assume sagging mounts also sit the motor forward as well? that would eat up clearance in a hurry.
Old May 3, 2014 | 11:06 AM
br549A1's Avatar
br549A1
I'd take a quick look. Seems like all have the problem. I think a worn front or rear or both will allow it to rock forward. You should be able to see all or part of the mount from behind the front tire. The rear mount on the other hand is a real pain. I hated every second of replacing that one
Old May 3, 2014 | 12:44 PM
John_K's Avatar
John_K
First I gotta remove the hideous Kuryakyn nose off the front mount, and that's held on by the two frame bolts. Engine will probably shift when I remove them and it'll be fun times trying to align the holes again. Can't wait.
Old May 3, 2014 | 12:47 PM
br549A1's Avatar
br549A1
It won't be bad. Crow bar or big screwdriver some rags so you won't scratch anything and a scissor jack and piece of wood to hold and raise engine as needed. Just get it upright first it's harder on the side stand but you can still do it if you don't have a stand.
Old May 3, 2014 | 03:13 PM
KEYBEAR's Avatar
KEYBEAR
Or you can check maybe you just need to rotate the header pipe just a little ?
Old May 4, 2014 | 02:28 AM
John_K's Avatar
John_K
looks like engine is shifted about a 1/4" forward in the mount from rubber sag, and who knows how far down. I shimmed the mount back with the slotted spacer that was holding the Kury nose in place, maybe an 1/8, and should bring it up a hair also. We'll see how the pipe fits back in place, but I foresee new engine mounts in my future budget.
Old May 4, 2014 | 04:12 AM
br549A1's Avatar
br549A1
It will keep you on the road until you can get the new mount in. You'll have a couple options, I think there's three including the stock. Make sure you read some other threads there's a lot of info on the various mounts.
Ss69camaro7
Jan 5, 2019 10:47 PM
nbowen805
Feb 8, 2018 10:43 PM
redmosquito1
Apr 16, 2013 10:08 PM
KingCustomCycles
Sep 13, 2010 10:30 AM
ripper43
Feb 28, 2008 10:36 AM
