Heel Toe Shifter
Old Sep 14, 2014 | 09:23 PM
rjo3491's Avatar
rjo3491
Default Heel Toe Shifter
Anybody have a heel / toe shifter AND forward controls. Had this on a Honda (with standard levers and floor boards) years ago and really enjoyed it. I guess it can be done - the mechanic at the dealer said Switchbacks come in this configuration, though they didn't have one in stock. A photo as well would be much appreciated.
Jay
Old Sep 14, 2014 | 09:27 PM
JBGILL06's Avatar
JBGILL06
3rd Gear
The Switchbacks do not come with a heal/toe set-up.
Old Sep 14, 2014 | 09:49 PM
katrina05's Avatar
katrina05
Jay
See the following thread:
https://www.hdforums.com/forum/dyna-...-w-pics-7.html
__________________________________________________ _________
Old Sep 14, 2014 | 10:04 PM
pntmachine's Avatar
pntmachine
You can take a inner shift rod arm off a Soft Tail pn33668-07 and grind the weld to remove the pin. Then do the same on the inner Switchback arm pn33789-90B and weld the longer spline shaft off the Soft Tail to the Switchback arm. The weld will be to the inside and not really show or you can rechrome if needed.
Old Sep 14, 2014 | 11:49 PM
rjo3491's Avatar
rjo3491
Looks like you're right. He may have misread the service manual. This looks more involved than I thought. I'm happy with the forward controls. I may just live with it the way it is.
Old Sep 14, 2014 | 11:55 PM
128auto's Avatar
128auto
Did you read my post? $35 heel toe lever, 15mins job. https://www.hdforums.com/forum/dyna-glide-models/905605-heel-toe-shifter-and-pegs-installed-w-pics-7.html
Old Sep 15, 2014 | 05:50 AM
target64's Avatar
target64
Vtwin # 21-0681 fits right on the dyna shift shaft. it a 10 min repair.got mine from M&M cycles this spring.
Old Sep 15, 2014 | 06:07 AM
pab3rd's Avatar
pab3rd
14 Lowrider with forward controls and a heal toe shifter from M&M cycle. Works fine, but only comes in chrome, so still need to powder coat it black.
Old Sep 15, 2014 | 11:27 AM
JRK5892's Avatar
JRK5892
i made my own... first thing i did was get a shifter arm as well as a shifter lever from a touring bike, cut he spines off the arm. and weld that to the shifter lever
i am running boards on mine off the foward mounts so i needed the heel to clear the board so i had to add 1" to the lever, some round bar and some grinding helped this issue
all powder coated and installed, i did order a extended peg and put the stock on on the heel and the longer one on the toe
I LOVE THIS, no idea how i lived without it
e11charlie
Jul 2, 2020 06:48 AM
Julia's Dad
Feb 17, 2016 11:25 PM
silvam
2014-2024 Touring Models
27
Jun 11, 2014 04:43 PM
scottgenghiswong
Jun 23, 2010 06:35 AM
lowridermike
Jun 1, 2009 09:15 PM
