Question for the mechanics
Old Feb 15, 2015 | 01:21 PM
Gliden's Avatar
Gliden
Thumbs up Question for the mechanics
Is there a quality stator replacement over the stock hd stator?
I see varied makes and manufactures in the jp cycle book.
I'm just wondering what you guys would install in your own bikes if your stator went bad?
Another hd or ?
Thanks for your input.
Old Feb 16, 2015 | 07:25 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Cycle Electric
Old Feb 16, 2015 | 07:36 PM
Gliden's Avatar
Gliden
Cycle Electric
Thanks Dan.
In your opinion better quality over stock I guess?
Old Feb 16, 2015 | 07:38 PM
Scrmnvtwins's Avatar
Scrmnvtwins
I have only had to replace 2 in 5 Harleys over 35 years, so I replaced with Original equipment.
Old Feb 16, 2015 | 07:46 PM
Gliden's Avatar
Gliden
Good point.
When both went bad did they just stop putting out ac or did they self destruct in the process and damage anything?
Old Feb 16, 2015 | 07:54 PM
Smokey Stover's Avatar
Smokey Stover
I'm no mech but I do my own work, Looking at replacing mine because that stupid rubber seal/plug started leaking. I know newer stators come with a new improved seal but would like to look at other options/opinions as well. I did the clean and injected some RTV temp fix, So far not leaking anymore but for how long?...
Old Feb 16, 2015 | 08:03 PM
Scrmnvtwins
in both failed units the circuit went open with a break in the magnet wire and no longer generated Alternating Current. Basically the stator puts out AC rectified by a diode bridge in your voltage regulator to rectify AC to DC. Start with the manual which I believe asks you to connect a multimeter between each of the stator leads. for AC. Root cause for stator failure is usually a break in the heavy copper magnet wire wrapped on the stator segments, a break in 1 of the wires, or a bad connector.
Old Feb 17, 2015 | 04:06 PM
Gliden's Avatar
Gliden
Thanks....I have low charging voltage. Barely acceptable at 13.7.
I need to test out the stator plug as per the manual and see what ac voltage comes out per the various Rpm's.
finespun automation llc
Electrical/Lighting/Alarm
Feb 7, 2018 12:00 PM
UltraClassicWNY
Apr 10, 2016 06:48 PM
Pitbull_Dallas
Apr 29, 2015 02:35 PM
fergerburger
Shovelhead
Nov 4, 2014 05:10 PM
rpmpit
Jun 14, 2013 07:14 AM
