Electra Glide Ignition Lock Removal *
Old Sep 16, 2005 | 08:36 PM
HDF Tech's Avatar
HDF Tech
Default Electra Glide Ignition Lock Removal *
Submitted by: FLRYDR Thanks Mark.
1. Turn the ignition KEY to unlock and leave the key inserted in lock assembly
2. Move ignition assembly to the "Off" position to unlock the forks. LEAVE THE KEY IN LOCK
3. Turn the Handlebars all the way to the right
4. With the ignition key still in the lock turn the LOCK ASSEMBLY to "Access"
5. Standing on the left side of the bike look at the lower left underside of the LOCK ASSEMBLY. You will see a small button in the rear left corner
6. Use a small screwdriver to depress the button and hold while pushing down on the KEY and turning it 60 degrees in the clockwise direction
7. Lift and remove ****
8. Reverse to reinstall except there is no need to depress the button
These direction came with a brushed aluminum kit that fits under the lock and over the cruise,spot etc switch on Electra Glide models. Worked great for me.
HBGB89
Jun 2, 2024 12:26 AM
Ashnic
General Topics/Tech Tips
14
Jun 6, 2019 11:37 AM
thatguy00
Aug 23, 2018 11:38 AM
5wheels
Feb 23, 2017 08:42 PM
FX4 Level II
Feb 5, 2009 02:29 PM
